RCU Forums
-   Airplanes - Full Scale (https://www.rcuniverse.com/forum/airplanes-full-scale-255/)
-   -   help help help (https://www.rcuniverse.com/forum/airplanes-full-scale-255/10894348-help-help-help.html)
kruccifranco 01-06-2012 03:41 AM
help help help
<span class="hps">Hello,</span> <span class="hps">my name is</span> <span class="hps">frank,</span> <span class="hps">I'm Italian</span><span>,</span> <span class="hps">I am writing to</span> <span class="hps">know if</span> <span class="hps">anyone can</span> <span class="hps">help me with</span> <span class="hps">the construction of</span> <span class="hps">a zero</span> <span class="hps">royal</span> <span class="hps">marutaka</span> <span class="hps">.60</span><span>.</span>
<span class="hps">in</span> <span class="hps">my kit</span> <span class="hps">there was no</span> <span class="hps">construction manual</span><span>.</span>
<span class="hps">If</span> <span class="hps">someone had</span> <span class="hps">a copy</span> <span class="hps">I</span> <span class="hps">could do</span><span>?</span><span>?</span>
<span class="hps">Thank you</span> <span class="hps">in advance</span><span>.</span>
Breguet 01-06-2012 03:58 AM
RE: help help help
You could go here:
http://www.rcuniverse.com/forum/m_83...tm.htm#8570172
'7aso' in this thread seems to have the kit. He might be able to help you out.
