RCU Forums
-   Airplanes - Full Scale (https://www.rcuniverse.com/forum/airplanes-full-scale-255/)
-   -   Variable Pitch Prop (https://www.rcuniverse.com/forum/airplanes-full-scale-255/2368849-variable-pitch-prop.html)
alfa156 11-23-2004 09:24 AM
Variable Pitch Prop
Hello
Wonder if there are variable pitch (controlled via RC) for small props (e.g. 22"):D
GEARED 11-23-2004 11:08 AM
RE: Variable Pitch Prop
Yes, I have seen ( here in rcuniverse) pictures of a variable pitcht 3-blade prop on a 100" wingspan turboprop Tucano build by someone in Austria. You should search for tucano, or turboprop or even variable pitch. Sorry for not being more specific. Good luck.
geared
HalH 11-23-2004 11:25 AM
There is a place that makes a prop that the pitch may be changed however it must be done while not in motion. I believe it would require some sort of hyraulic pressure to change the pitch when airborne.
smokingcrater 11-23-2004 02:31 PM
or a heli setup... I've seen some variable pitch setups that basically use a pitch slider and swashplate from a rc heli... no hydralics, just one extra servo.
grinder-RCU 11-24-2004 12:55 AM
http://www.jakadofsky.com/htm_en/welcome.htm
Solo props also makes an ground adjustable prop.
http://www.soloprops.com/index.html
Grinder.
alfa156 11-24-2004 10:03 AM
Not bad.
Don't really fancy the helicopter setup ..... might get really flimsy at higher revs right?
But I do like adjusting the pitch on the fly.:D
Wonder if there are ready made systems that we could buy.:eek:
alfa156 12-07-2004 10:21 AM
Updatez .............
No ready made var pitch prop???
