Old Airtronics Servo Compatability
I just got an Airtronics SD-10G transmitter with a 92674 7 channel receiver. Will older Airtronics analog servo's work with this receiver? If they will work do I just need to change out the connectors and put on Z's?
Trey
Trey
Hello,
Those servos will work with any of the ATX FH1 receivers like the 92674. You'll just need to change the connectors, making sure to double-check polarity. They more than likely won't work with the ATX FH3 receivers.
Best regards,
Todd
Best regards,
Todd
CO
Use these they work great. I am a big Airtronics both old and new.
http://www.hobbypeople.net/index.php...-receiver.html
I think you can do that, I just thought someone might have a bulk package of the connectors sans wires. Might save a few bucks. I'll probably go ahead and get a handful of the servo wires with Z connectors and do the swap.
Of course you can - done it many times. Why pay $5 when you can changed the connector wires around for nothing?
