airtronics transmitter low voltage alarm change
I have a new Airtronic 8 channel 2.4 radio. I want to change the low voltage warning alarm on the radio. Is there a way to change it to a higher voltage? I'm using a lipo now and the old battary could go down to 9.5 or there about before a problem. The lipo drain curve voltage drops off quick below 10.3 volts.
I want to change the warning alarm to about 10.8.
Anyone know how?
Anyone know how?
If you have the RDS8000, even though it can be used with a 3S LiPo, I don't believe there's any way to change the low voltage alarm. At the time, that radio was never really designed with the idea that user's would be using a completely different type of battery other than NiCds or NiMH.
Best regards,
Todd
Best regards,
Todd
Just keep checking the voltage each time you use it. I have the same problem with my SD 10G and it was designed to use a 2 cell lipo and still no alarm when it gets down to the low voltage cut off. I love my radio but they should have fixed this issue.
Moderator
Airtronics/Sanwa has many issues to fix, but isn't interested in addressing any of them. That's why they are gone as a presence in the US RC market.
