Flap on throttle stick
I like to have my flap set up on the throttle stick and switch to crow for landing (gliders) is there a way o do this with the SD10....Tankey
RE: Flap on throttle stick
This is done with the Glider template and practicly already setup for you.
Just load the glider template and try it. MIke R |
Where do I find this template?
I going to assune you are new to full house gliders and programming any radio based on your questions.
Start out by reviewing the radio manual. It is one of the best. Then begin on pg 25 learning how to sekect a model type. Such as a glider. Then pg 125 for sail plane specufic guidance. Give it a whirl and expetiment. Then I and others can help with dialing it in. Mike R Oh and specificly under the SYSTEM MENU. ORIGINAL: tankey Where do I find this template? |
