SD 10d Aileron Stick broken
Hi,
My aileron stick wont center from left aileron. There are 2 small metal pins that are attached to the aileron stick. These pins rest against the metal bar which provides centering via the spring tensioner. One of these has broken. I would like to get a stick assembly or just the "stick base"? I have found Global Services Original Replacement Parts listing. They list a stick assembly Item no. 496447 and also a Stick Base Part No 493371. Can anyone tell me exactly what the stick base is and if it is the part that has the metal pins? Thanks, Any help is apprecaited Dave . |
Hi Dave,
The stick assembly is no longer in stock and we can't get any more. The stick base shows in stock (493371), but I'm not exactly sure what it consists of. I would recommend you call customer service at 714-963-0329 and they can check for you and let you know. Best regards, Todd |
Thank you for the information.
Dave |
| All times are GMT -8. The time now is 08:59 AM. |
