Difference in rule change forms, which is correct?
I have found that the current rule form posted on the AMA site as #333 PDF rule change is different than the one that was adopted in the the new documents contained in the new contest board procedure's. The difference is the current posted #333 requires only three current open members to sign the proposal and the form in the new contest board procedure's requires two open members and one contest director. I have emailed Steve Kaluf but with the weather causing the power outages in Muncie, and headquarters being closed, I have heard nothing back. Does anyone have any insight as to which for is correct? I hate to just assume ( you know what that stands for) its the new one in the contest board procedure's but if I had a choice I would probably select it.
Thanks, Marty King AMA 39945 NSRCA 2551 D-4 |
RE: Difference in rule change forms, which is correct?
The EC discussed the change, to require two open members and a CD on the request for a rule change, at the Feb 2004 EC meeting. The change was approved at the April Meeting as part of the new Contest Board Procedures. Get a CD to sign. The change was effective 1/1/05.
The new rule book, and changes associated with it, were to be up on the AMA site on about 1/1/05, but weather has slowed the process, just as you guessed. |
Thanks JR,
Thats what I figured but I sure do like to have confimation. Marty |
| All times are GMT -8. The time now is 05:24 PM. |
