RCU Forums
-   AMA Discussions (https://www.rcuniverse.com/forum/ama-discussions-74/)
-   -   AMA policy help needed (https://www.rcuniverse.com/forum/ama-discussions-74/4154411-ama-policy-help-needed.html)
N12932 04-11-2006 09:24 PM
Does AMA have anything against mounting model rocket engines on model planes? It may sound strange but i have designed a rig to use them but dont know if it would be legal.
MajorTomski 04-11-2006 09:28 PM
RE: AMA policy help needed
See here
http://www.modelaircraft.org/PDF-files/105.pdf
Item 8 under GENERAL
Tom S
AMA 8026
N12932 04-11-2006 09:30 PM
Thanks i couldnt find that
redfox435cat 04-11-2006 09:34 PM
darn I knew I shouldn't of done that[:'(]
Dr1Driver 04-12-2006 10:01 PM
Sorry, Charlie. Re-read #8. It prohibits FIRING a pyro device from a plane. It does NOT prohibit PROPELLING a plane using a solid fuel rocket engine up to a G series, PROVIDED the engine REMAINS ATTACHED to the plane during flight. In fact, Estes has had a rocket powered R/C plane out for many years. It has been favorably reviewed in R/C Report magazine.
Dr.1
redfox435cat 04-13-2006 07:09 PM
I forgot what the new one is called, I have the strato blaster (estes). it's a fun little plane. slope soarer rocket glider or cox motor in one plane. :D
carwood444 04-15-2006 09:24 PM
Keep me updated on this, it sounds interesting. I can think of a couple applications for something like that.
50+AirYears 04-22-2006 10:41 PM
Estes has a series of plugged motors for the R/C rocket powered boost gliders. Aerotech has a couple reloadable moters for the same purpose.
As someone said earlier, it's perfectly ok to use a rocket motor on a plane as long as the spent casing is not droped from the plane. In fact, a number of perfectly legal r/c and free flight boost gliders mount the motors on a detachable pod that uses a standard parachute or ribbon recovery system.
