CD's
What is the difference between a CD and a CD for a turbine waiver.Can any CD sign off a person for a turbine waiver?
RE: CD's
The difference between a CD and a Turbine CD, is that a Turbine CD not only holds the CD designation but also possesses a turbine waiver.
If you are applying for a fixed wing turbine waiver, you need two signatures, one from any waiver holder and the other from any Turbine CD. There is also a small list of Designated Turbine CD's. See AMA pub 510k. The folks on this list are the only ones that can sign off on "rotary" turbine waivers. |
RE: CD's
I'm allready a turbine waiverd pilot if I took the test for a cd then I would be able to sign off people for a waiver?Not that I want to be a cd but am curious as to how it works.
Thanks |
RE: CD's
ORIGINAL: funflyerf4 I'm allready a turbine waiverd pilot if I took the test for a cd then I would be able to sign off people for a waiver?Not that I want to be a cd but am curious as to how it works. Thanks |
RE: CD's
Nevermind. Wanted to know how much experience is required for stuff like this.:D
RE: CD's
ORIGINAL: busted2props Nevermind. Wanted to know how much experience is required for stuff like this.:D There is some responsibility and risk that comes with the CD waiver signoff. If you sign someone off who is really not qualified, and they go out and hurt someone, there is a high probability that the lawyers will find you. |
RE: CD's
ORIGINAL: pilott28 There is some responsibility and risk that comes with the CD waiver signoff. If you sign someone off who is really not qualified, and they go out and hurt someone, there is a high probability that the lawyers will find you. There is some responsibility and risk that comes with the CD waiver signoff. If you sign someone off and they go out and hurt someone, there is a high probability that the lawyers will find you. The term “Qualified" will likely be determined during any litigation where serious injury takes place... your friends may also be there giving their unique and subjective observations as well. The waiver system allows the diffusion of personal responsibility. Many look at the waiver system as just the means of qualifying for turbine operation but it is much more than that…technically turbines are prohibited within the AMA but that prohibition can be waived providing someone will sign on the appropriate dotted lines… |
RE: CD's
PILOTT28 and LCS,
Thanks for the info. Kinda thought it worked that way. Goes down all the streets to the original signature. HMMMM...Makes ya think, don't it?????????:eek: (Don't it was intentional.) |
RE: CD's
ORIGINAL: littlecrankshaf ORIGINAL: pilott28 There is some responsibility and risk that comes with the CD waiver signoff. If you sign someone off who is really not qualified, and they go out and hurt someone, there is a high probability that the lawyers will find you. There is some responsibility and risk that comes with the CD waiver signoff. If you sign someone off and they go out and hurt someone, there is a high probability that the lawyers will find you. The term “Qualified" will likely be determined during any litigation where serious injury takes place... your friends may also be there giving their unique and subjective observations as well. The waiver system allows the diffusion of personal responsibility. Many look at the waiver system as just the means of qualifying for turbine operation but it is much more than that…technically turbines are prohibited within the AMA but that prohibition can be waived providing someone will sign on the appropriate dotted lines… In the 15 or so years the turbine wavier system has been in place I have never heard of a CD being sued has anyone else? |
RE: CD's
ORIGINAL: ira d ORIGINAL: littlecrankshaf ORIGINAL: pilott28 There is some responsibility and risk that comes with the CD waiver signoff. If you sign someone off who is really not qualified, and they go out and hurt someone, there is a high probability that the lawyers will find you. There is some responsibility and risk that comes with the CD waiver signoff. If you sign someone off and they go out and hurt someone, there is a high probability that the lawyers will find you. The term “Qualified" will likely be determined during any litigation where serious injury takes place... your friends may also be there giving their unique and subjective observations as well. The waiver system allows the diffusion of personal responsibility. Many look at the waiver system as just the means of qualifying for turbine operation but it is much more than that…technically turbines are prohibited within the AMA but that prohibition can be waived providing someone will sign on the appropriate dotted lines… In the 15 or so years the turbine wavier system has been in place I have never heard of a CD being sued has anyone else? |
RE: CD's
...this suing thing is used all too often to justify most any restriction...it works quite well. Heck, AMA likely owes its whole existence to the concept. |
RE: CD's
ORIGINAL: BarracudaHockey Hmm.....I was under the impression that is was a way to organize modelers for the common good. To present ourselves as a body to goverment agencies to get the frequencies we use, to organize events, to communicate with each other, and to promote the hobbby. I may be unusual in that I truly believe the hobby, although different would continue without the AMA. I base that belief on the fact that I built and flew models long before I knew about AMA and its benefits. Yes, there are benefits. We just need to learn how to use them properly. That is why I counter those that hinge what they say on fear……………………………………… ………………………………………… ………………………………………… ……………….That is not the right answer. We need to move from there. |
RE: CD's
nvm
RE: CD's
ORIGINAL: littlecrankshaf ORIGINAL: BarracudaHockey Hmm.....I was under the impression that is was a way to organize modelers for the common good. To present ourselves as a body to goverment agencies to get the frequencies we use, to organize events, to communicate with each other, and to promote the hobbby. I may be unusual in that I truly believe the hobby, although different would continue without the AMA. I base that belief on the fact that I built and flew models long before I knew about AMA and its benefits. Yes, there are benefits. We just need to learn how to use them properly. That is why I counter those that hinge what they say on fear……………………………………… ………………………………………… ………………………………………… ……………….That is not the right answer. We need to move from there. I am suspending my LCS ban for a short time here to un-twist and de-spin the above. Today, you must be protected from the sharks swimming in circles around people engaging in any "potentially hazardous" activity. AMA has simply made it easy, cheap, and uniform(for administrative purposes for clubs, individuals, and governments) to insure against legal problems. Insurance may be the largest factor for joining AMA, but due to today's circumstances, not because AMA has steered it that way. You , o' sage one, may deny that, but your head is clearly buried neck deep in sand if you can't recognize that AMA has done far more as a large group than a nationwide collection of individuals could ever hope to. Yes, you truly are unusual, but be that as it may, the fact is we would have far fewer places to fly, far fewer planes to fly, and most likely, far fewer people enjoying this hobby. And aside and maybe above all that, it still is everything BarracudaHockey mentioned above. |
RE: CD's
Ah! A well thought out and lucid post (and completely true). So rare in a discussion of the AMA. [sm=thumbs_up.gif][sm=thumbs_up.gif][sm=thumbs_up.gif]
RE: CD's
nvm
RE: CD's
ORIGINAL: 804 I am suspending my LCS ban for a short time here to un-twist and de-spin the above. Funny thing is that your post bolsters mine but your spin is the commonly used version. |
RE: CD's
AMA has simply made it easy, cheap, and uniform(for administrative purposes for clubs, individuals, and governments) to insure against legal problems you are equating the PPP one half of one million coverage with the multimillion AMA coverage? That kind of uniformity? Everyone is the same, except for the ones that arent. |
RE: CD's
ORIGINAL: littlecrankshaf ORIGINAL: 804 I am suspending my LCS ban for a short time here to un-twist and de-spin the above. Funny thing is that your post bolsters mine but your spin is the commonly used version. If you're saying I shouldn't try to spin a spinner, you're probably right.:) But you're wrong about me blocking you. I told you in the PM I wasn't going to, remember? In the hope Ken doesn't lock this thread, I'll say no more. |
RE: CD's
ORIGINAL: KidEpoxy AMA has simply made it easy, cheap, and uniform(for administrative purposes for clubs, individuals, and governments) to insure against legal problems you are equating the PPP one half of one million coverage with the multimillion AMA coverage? That kind of uniformity? Everyone is the same, except for the ones that arent. |
RE: CD's
ORIGINAL: 804 I told you in the PM I wasn't going to, remember? Now, just why should I believe anything you have to say...You say one thing but yet another is the truth. Do you remember? |
RE: CD's
Funflyer, appologies for your simple question getting hijacked and degraded. I hope by the time you get up and check in on this it will have been cleaned up.
RE: CD's
That is what is indeed openly touted but it is also a greater truth that without the spell of "fear factor" instilled and the provided "antidote" of insurance by the AMA it would be a certainty that AMA would not have survived until today. I am one that regrets deeply that the AMA only survives due to insurance because of the fear of modeling. How do these other organization stay afloat without insurance? All of them provide magazines. All of the provide internal support and liaisons to a higher authorities to keep their organizations where they are today, safe and happpy. All of them provide event sanctions (yes, sanctions don't always need to have insuance included) and an array of benefits to their enthusiasts. So who would keep the restrictions away from the aeromodelers if the day ever came there was no AMA, you? There would only be a pathway so guys like Chuck Schumer and Co whom presume our hobby "could be" dangerous, without some kind of National body (150,000 members) to protect it, in his case would be 100% right. Members would remain members because it's been proven to work in other hobby orgs that DO NOT provide insurance, the data is alive and working. AMA does not put any kind of fear into anyone. Headlines and these threads put in the fear .... but when I goto to the field, I see nothing but pleasantries. |
RE: CD's
:D Only if he is Rip Van Winkle! :)
RE: CD's
I hope by the time you get up and check in on this it will have been cleaned up. |
| All times are GMT -8. The time now is 02:06 PM. |
