RCU Forums
-   AMA Discussions (https://www.rcuniverse.com/forum/ama-discussions-74/)
-   -   Crashing is NOT an option, M A article! (https://www.rcuniverse.com/forum/ama-discussions-74/9214982-crashing-not-option-m-article.html)
combatpigg 11-01-2009 02:41 PM
RE: Crashing is NOT an option, M A article!
After stopping to consider what could be interfering at this field, there is a remotely controlled and monitored gas pipeline that runs through it. I can see radio repeater towers here and there. We are on the outskirts of an industrial area...I can really only imagine why this RX under-performed. It works great if you fly within 600 feet or so, like doing practice pylon laps. I just sent the RX in to Futaba.
Back when I just flew run of the mill lower performance stuff with standard sized equipment, the components seemed to last forever. Most all my problems were pilot/operator related, like trying to get 1 last flight in before sundown with a questionable pack, trying to fly with a loose antenna in the TX, etc., stuff like that. Those lower revving, slower planes had a much higher tolerance and would signal possible problems better in advance and give you more time to take corrective action.
Rafael23cc 11-01-2009 09:35 PM
ORIGINAL: combatpigg
If you aren't intelligent enough to see how the range check I described can reveal problems that the ''regular'' check doesn't reveal, it's a waste of my time trying to explain it to you.
I will take the time to tell you that only a fool would try to pass judgement on my track record and abilities based on the case you are trying to make here. My advice to you is get a hobby that you can be good at. You'll feel so much better about yourself that you won't feel the need to insult guys to make up for your own failures.
I see that you resort to insult when people confront you. I will not sink to your level.
After reading your subsequent posts I realize that your situation is unique to your field. Suggesting that the rest of us do the same thing (running around with a running engine and the plane on your arms while the TX has an EXTENDED antenna at the pits) is absolutely inadequate.
Now lets go fly, this discussion has run its course.
Rafael
combatpigg 11-01-2009 11:05 PM
Funny how you can dish it out, but can not take it. You went well past simple confrontation and don't like the taste of your own medicine.
The problem with this field is not unique, if it can happen here, it can happen elsewhere.
This test will either confirm suspicions, or it might not. It can also be used to gain confidence in a new set up. Regardless it is a proven "tool" that you can choose to either use or not without laying that "mentality" BS on me, slick.
littlecrankshaf 11-02-2009 12:19 AM
ORIGINAL: Rafael23cc
Rafael
UMMM...Funny...not so fast... we seem to have the same situation at our field...we call it coffin corner... pipeline and radio towers may also be the problem here as well. The better radio receivers seem to have less problems but the old single conversion as well as some of the dual conversion types such as Futaba’s 127s and the like consistently have issues in that particular area.
KidEpoxy 11-02-2009 10:15 AM
I find it absolutely plausible that
the radio interference (or lack there of) at the pits/pilotstations
may not be the same as the interference found at spots out in the flying area.
Seems the article would be putting the blame for going down in Coffin Corner
squarely on faulty procedures by the pilot:
Should have checked the field RF patterns prior to going up.... careless pilot negligence to save time and effort cost them that plane.
dreadnaut 11-02-2009 11:04 AM
ORIGINAL: dreadnaut
Years ago when I used to fly at Sepulveda basin, there were a number of ''experts'' who would grab an unsuspecting newby and volunteer as instructor. The problem is that while a lot of these guys had some stick skill, they were horrible teachers. Lesson 1; ''I am totaly awsome, and you should strive to be just like me'' Lesson 2;''Don't listen to that other jerk because he doesn't know how to buzz the runway inverted'' Lesson 3;''All planes are doomed to crash, it's only a matter of when''
I liked the article, and agree that the ''all planes must crash'' attitude in not an absolute. One thing I would add to Don's list is; Learn to fly from someone who's biggest skill is explaining the principles, and has an attitude that crashing, while a possibility, is not a given.
ORIGINAL: combatpig
If you aren't intelligent enough to see how the range check I described can reveal problems that the "regular" check doesn't reveal, it's a waste of my time trying to explain it to you.
Wow, that sounds like lesson one and lesson two.
Robotech 11-02-2009 11:50 AM
ORIGINAL: KidEpoxy
One would hope that the friendly folks at the field would forwarn. We do at our field. "You on a high channel with a Futaba 127? You're gonna get a little bump when you cross the pipeline." "Gee, thanks for the heads up."
There's always that first guy that found it though. [:@]
HighPlains 11-02-2009 11:55 AM
I would venture a guess that most RC pilots have not flown at very many fields. Maybe 90% or more have experience at 5 fields or less. After flying at well over a 100, I have to say that there are certain "dead zones" that were problematic for some receivers at a small number of fields. However, most of the time it is the pilot pointing the antenna at the airplane, poor radio installations, and equipment that has smacked the ground a few times.
The high performance stuff that CP likes to play with will show problems much quicker than normal sport models.
Robotech 11-02-2009 01:39 PM
Here's a good quote;
"........ in contrast, the modeling world often depends on well-meaning but sometimes misinformed opinions and Internet threads written by modelers and RC flight instructors who are trying to help but teach with incorrect information, because that's how they were taught. When faulty information is repeated long enough, it usually becomes fact because so many believe it."
Emphasis added.
W-w-w-what? What in the cat hair is he trying to say. Is there a name for it?
Mode One 11-02-2009 02:32 PM
ORIGINAL: Robotech
''........ in contrast, the modeling world often depends on well-meaning but sometimes misinformed opinions and Internet threads written by modelers and RC flight instructors who are trying to help but teach with incorrect information, because that's how they were taught. When faulty information is repeated long enough, it usually becomes fact because so many believe it.''
Emphasis added.
I have certainly seen miss-information and bad advice given on the internet! Heck I've prolly even given some! This is certainly not suprising to me, is it to anyone else?
combatpigg 11-02-2009 02:35 PM
I've learned more from the 6 years of coming to RCU for education and advice than 10 lifetimes worth of hanging around the old flying field. I will say though that getting involved in some form of competition will speed up the learning rate many times, too.
The statement about the internet being a breeding ground of false information can be applied anywhere else.
Believe it or not, before there was an internet, bad advice still flourished everywhere.
The modeling World does not often depend on any such thing like bad internet advice, never has, never will.
cj_rumley 11-02-2009 03:14 PM
Wasn't that the same MA issue that had another article advising folks to hang weights on the wingtip to counteract torque?:eek:
combatpigg 11-02-2009 03:25 PM
:D!!
I wonder how many hundreds of guys raced out to the field to try that one out?
bradpaul 11-02-2009 03:25 PM
ORIGINAL: cj_rumley
No you got that one wrong......... try again to get a MA slam in.
combatpigg 11-02-2009 03:29 PM
....he put it that way to be funny and he did a heck of a good job. :D
bradpaul 11-02-2009 03:40 PM
Funny like in smells funny?
Jim Thomerson 11-02-2009 04:54 PM
I'm puzzled, but not surprized, by the somewhat negative tone of posts on the article. I sort of skimmed it, as I don't fly RC, but I thought the major principles were well worth noticing. I doubt that your ratio of crashes per flight would go up as a result of digesting the article. In terms of advice; combatpigg's comment that you rapidly learn a lot of good stuff in competition is right on. I can't right off think of any one whom I regard as "expert" who has not flown competitively. On the other hand, I usually value my own experience over expert advice which contradicts it. In competition, you have a group of colleagues and you are all in agreement as to what is important. That is one of the things I like about competition. I'd also note that things which work for me may not work for others; and thus I might give bad advice.
Robotech 11-02-2009 05:25 PM
ORIGINAL: Robotech
Emphasis added.
Man, I put a perfectly good cricket on that hook and not a single bite. [:@] All the fish must be feeding on the bottom.
Robotech 11-02-2009 05:27 PM
ORIGINAL: bradpaul
"Not ha-ha funny, peculiar I guess.".. The Eels.
804 11-02-2009 07:04 PM
It was a good how-to, the guy is pretty much right about everything he says. But I saw nothing I haven't seen here or on other forums. Most who read it probably aren't past deadsticks and dumbthumbs far enough to even think about redundant systems, amperage draw, regulators, and the like.
KidEpoxy 11-02-2009 09:52 PM
The internet and magazines are full of great advice.
From the internet I learned about cutting open a rechargable rectangular "9v" battery (actually a 7.2v)
and using 4 of the 6 itty-bitty cells inside to make a 4.8 flight pack
... two "9v" batts yield 3 flight packs, cause you're gonna want to swap them out between flights
I also learned about the correlation between building too heavy and folding the wings under G's:D
kurt2022 11-02-2009 10:18 PM
I used to have some glitch and fail-safe problems but since I made the quantum leap to spektrum 2.4 I have never had as much as a glitch! I see that you can't even give away 72mhz stuff anymore, I WONDER WHY?
tbirdaerospace033 11-02-2009 10:49 PM
From what I've seen, part of the problem is the ARF's themselves.
I was out of the hobby for a while, got back in a few years ago, put some ARF's together and have spent more time repairing "shotty" workmanship on the ARF's than actually flying them.
I'm going back to building kits. That way I know the glue joints are secure, and if reinforcement is needed, I can do it in the building process.
I am convinced that with average piloting skills, a kit built plane will last longer than an ARF.
combatpigg 11-03-2009 12:17 AM
If you lined up all the planes end to end that have been stuffed flying on 2.4, they would circle the globe.
Careful Tbird, you don't want to give the vast majority of ARFers who read this forum more reasons for self loathing........;)
804 11-03-2009 08:27 AM
ORIGINAL: tbirdaerospace033
I was out of the hobby for a while, got back in a few years ago, put some ARF's together and have spent more time repairing ''shotty'' workmanship on the ARF's than actually flying them.
I've had just the opposite experience. In six years, I've assembled, and flown the crap out of, about 25 Arfs, from small electrics to 50cc gas. 5 to 30 minutes spent checking glue joints and particularly engine mounts goes a long way. Done right the first time, I have spent very little time repairing anything I didn't cause myself.
