Flying at a state park or lake
will you be coverd flying at a state park or lake by the AMA there is no club there just some guys flying float planes in the winter months off the water
Theses are nitro planes thanks Tim |
RE: Flying at a state park or lake
long as ya are not breaking any laws by flying there, ya should be covered. however, i would verify any information i got on a forum with a call to ilona maine at ama hq.
Tim
Remember that your AMA pilots insurance is good anywhere you are allowed to fly, while it is the SITE insurance clubs get to protect the club and landowners. |
I think the key factor is whether you have permission to fly at the park. The absence of a specific restriction may not be interpreted as permission.
Brad |
"The absence of a specific restriction may not be interpreted as permission"
I disagree. Public use areas usually have a list of what not to do, even what not to drink sometimes, if there is not a rule (or local/state/fed law) against it, why would we think it was not permitted? I dont see a restriction on playing solitaire on the park bench, where does that fit in your interpretation of permitted? Its the land of the free, with certain restrictions (which we have LOTS of), not the land of the restricted with certain permissions. |
The operative term was "may not", as opposed to "does not". "May not" is normally interpreted as either case could be correct, depending on the situation. In other words, the OP should ensure that the activity is not specifically prohibited, and further that park officials don't interpret other restrictiions (e.g., restriction about noise, restrictions about "hazardous" activities, etc.). AMA is pretty specific about ensuring you have permission to use the property. An assumption on the OPs part that they have permission may not be valid. Should something happen that might require the insurance, and there isn't a clear assurance that the activity was permissible, then the insurance might not cover it.
Its always better to have a clearly expressed permission to use the land for flying, particularly if you're concerned about the AMA insurance coverage, rather than assuming you have permission because its a park. As an example, in our area, park authorities have specifically told people not to fly airplanes in the parks, although there is no specific written prohibition. Should someone be injured as a result, if asked, I feel quite certain the park authorities would say the individual did not have permission to fly there. Brad |
well we have never asked anyone if it was ok to fly we juststarted doing it about 20 years ago . The park rangers would come by and watch . they never kicked us out or said we could not fly in the park. we only fly out at the lake from about late sept - first of may then the water comes up on the boat ramps and the boaters use the parking lot tp park there trailers
this is a picturewhere we fly picture http://i971.photobucket.com/albums/a...1/PICT0077.jpg |
I would say if you've been doing it for 20 years, and the park rangers have watched you without kicking you out, there's a strong case for arguing the implicit permission. You'd still be on firmer ground getting explicit permission.
Brad |
ORIGINAL: bkdavy The operative term was ''may not'', as opposed to ''does not''. ''May not'' is normally interpreted as either case could be correct, depending on the situation. In other words, the OP should ensure that the activity is not specifically prohibited, and further that park officials don't interpret other restrictiions (e.g., restriction about noise, restrictions about ''hazardous'' activities, etc.). AMA is pretty specific about ensuring you have permission to use the property. An assumption on the OPs part that they have permission may not be valid. Should something happen that might require the insurance, and there isn't a clear assurance that the activity was permissible, then the insurance might not cover it. Its always better to have a clearly expressed permission to use the land for flying, particularly if you're concerned about the AMA insurance coverage, rather than assuming you have permission because its a park. As an example, in our area, park authorities have specifically told people not to fly airplanes in the parks, although there is no specific written prohibition. Should someone be injured as a result, if asked, I feel quite certain the park authorities would say the individual did not have permission to fly there. Brad Not arguing, but where is this stated by AMA? I believe it used to be in the safety code, but no longer is. Any info? |
This is what I got from Ilona Maine
Thank you for your inquiry. AMA coverage is not limited to model flying at contests or at a club field. It also applies to flying on private property or at public parks. Please be sure to conduct your modeling activities in accordance with the current AMA Safety Code. Best regards, Ilona Maine Safety & Member Benefits Academy of Model Aeronautics |
I also asked this question on the AMA forum and received a reply from Ilona.
Permission is not needed, but a charge of trespassing will void coverage. Complete answer at: http://www.modelaircraft.org/forums/...5&mpage=1#2524 |
ORIGINAL: bradpaul //snip// Permission is not needed, but a charge of trespassing will void coverage. Complete answer at: http://www.modelaircraft.org/forums/...5&mpage=1#2524 On a more lighter reply, here in TX, trespassing is a serious item. Trespassing can certainly provide one with real "coverage" like some 6 feet of coverage. [sm=crying.gif] Any person that enters the private property of someone else without provable permission, IMO, deserves whatever he/she receives from the property owner. |
Here is the wording (emphasis mine):
Brad, The short answer is that you do not need the property owner’s permission for the AMA liability insurance to respond. Keep in mind, that any trespassing charges brought against an AMA member are not covered under the coverage provided to them by AMA. Please note that habitual trespassing in direct violation of a land owner's request due to an inherent danger could imperil insurance coverage. I would strongly urge everybody to get permission before using any property for their modeling operation. This isn’t about insurance coverage, but about common courtesy and good public relations for Aeromodeling and the people involved in this hobby. Ilona |
ORIGINAL: Hossfly On a more lighter reply, here in TX, trespassing is a serious item. Trespassing can certainly provide one with real "coverage" like some 6 feet of coverage. [sm=crying.gif] Any person that enters the private property of someone else without provable permission, IMO, deserves whatever he/she receives from the property owner. |
