ECOMRC TigerMoth 1/4 Scale
I am building the ECOMRCTigerMoth, this will be my first 1/4 scale Bi Plane.
On examining all the parts in the box I am pleased with the quality of the parts and the covering, all are covered in Pro Film. showing the wing and tail sections.
DB
DB
RE: ECOMRC TigerMoth 1/4 Scale
Hardware packed with all that you require, the Fuel tank comes with a Petrol bung (Not the Norm in many Kits)
All Nuts/Bolts Wire etc.
The Wing Tubes are all Carbon
I have decided to go with the DLE 30cc as I have used one of these and was very happy with it, purchased from Ian at IAD.
Thanks for that.
Moving onto the wing servos, the mountings have already been done for you so not much to do on there. All fitted very nice.
DB
DB
Hi,
I got it from YT Internatinal, heres the link:
http://www.ytinternational.co.uk/home.htm
They also do Pilots as well.
Cheers
DB
Cheers
DB
Hi Dan,
I have no issues with this set up, I have used this on many other planes some of large arobatics over many years and have had no issues. But thanks for your comments.
Cheers
DB
Cheers
DB
Moving onto the wing strut installation. It does not explain too well in instructions but I got them in the correct order.
They are number stamped on the mental ends
DB
DB
Moving onto the Rudder set up.
You have to install the push rods first and then install main arm in from the top. Check the holes that have been pre drilled as the outter ones are 3mm and the hardware is for 2mm. I used 3mm linkages instead.
Once in just install the bearing under and then install bolt.
DB
DB
