Reload this Page >
Peak Model 30cc MXSR
Old 12-16-2012, 10:04 AM
Mpizpilot
My Feedback: (45)
Default Peak Model 30cc MXSR
Just finished up a peak model MXSR. I'm very impressed with the airplane. One of the nicer ARF's I've put together in awhile. All the hardware was useable and pretty decent stuff. It comes with carbon tubes and landing gear as well. Spinner is a Carbon Fiber from TBM. Running a DLE 30 w/ stock exhaust, LIFe 2000mah on the rx, and 1400 on the ignition. Servos are Power HD 1501's and HK Orange 9 channel rx w/ satellite rx. Dennis from Kirby's Kustom Graphics did the vinyl package for me. The graphics that came with the plane were the only thing I wouldn't use. My canopy came damaged from shipping, all it took was one email and another was on it's way to me. All in all, besides the TF ARF's this was finally a satisfying expierence with an arf. Two thumbs up to Peak Models.
ID:	1830770   Click image for larger version
ID:	1830771   Click image for larger version
ID:	1830772   Click image for larger version
ID:	1830773   Click image for larger version
Old 12-16-2012, 10:46 AM
karolh
Default RE: Peak Model 30cc MXSR
Tell us about how it flies ..... please.
Karol
Old 12-16-2012, 11:50 AM
nitro wing
I have the 50cc version and it is a winner. I fly Extreme Flight, so my evaluation should count.
Peakmodels sent you a new canopy? Impressed, as they are not well known for supplying parts.
Old 12-16-2012, 12:52 PM
Mpizpilot
My Feedback: (45)
ORIGINAL: karolh
Karol
I will as soon as I get the chance. Weather here isn't as nice as in Jamaica, lol
Old 01-24-2013, 05:06 AM
BOLTMAN
BOLTMAN's Avatar
Beware of the wing tube on this model. I have seen one fail and heard of others.
I have the 50cc version on which I glued a metal tube inside the carbon one supplied.
You did well with the canopy, mine was also damaged and after 4 months of e-mails they finally sent me a replacement. Shame is that it is an exact replacement - it is broken too!
I was pretty un-impressed with the kit. Wing & tail tubes loose in the outers. Locator pegs for wing & tail a poor fit.
It does fly damn well though.
ID:	1843813   Click image for larger version
ID:	1843814   Click image for larger version
Old 04-07-2013, 03:56 AM
Mpizpilot
My Feedback: (45)
Finally got out to do the maiden flight yesterday. This is one fantastic flying airplane the DLE 30 is way more then enough motor. The control surfaces have massive amounts of authority. I only wish my JR 9303 tx had flight conditions like my last futaba tx. Now I'm stuck with either a super low rate or super high rate. For normal sport/IMAC type flying I had to dial the low rates way,way down. The elevator on this bird has just got gobs of power. On high, 3D type rates the nose will try to eat the tail in a waterfall or knife edge spin.
I had some tucking to the gear in knife edge, used about 4% mix to overcome. There was zero aileron coupling in knife edge. The balance point is perfect given in the manual, a roll to inverted on a 45 upline shows no change in pitch attitude.
I'm also impressed with how light the planes flies, especially in any high alpha type stuff. It's a real floater.
Only problem I had was with the garbage plastic wheel pants. On the last landing, the left wheel pant tore away. The right one is soon to follow. These should have been done in fiberglass.
I would post a picture, but once again rcu is acting up.
Old 05-08-2015, 07:49 AM
Sloviper
I am just about to finish my mxsr but i encountered a problem with the cowl. I have dle 35ra and it looks like the cowl doesnt fit in straight with the spinner backplate.
did you guys have the same problem?
Old 07-21-2015, 06:55 AM
john.j.allen
I had this problem when using ply spacers to move the motor forward, I've since switched to washers, and I'm using one washer on the cowl mount to compensate for the right/down thrust. It still does not align perfectly, but its just the way the cowl is made.
See https://goo.gl/photos/kM6B9TfAjEKn6ooP8
Old 10-01-2017, 05:26 AM
john.j.allen
I've finally got my MXS-R back in the air (still tuning the DLE30), but as I feed in up elevator once I reach a certain point the model rolls hard left. Anybody else experience this?
