Great Planes new Escapade for DLE 30cc? >
Old 04-19-2015, 08:00 PM
  #126
jet22b's Avatar
Super08;
Looking good!!! I like the way you ran the plug lead!!! It is getting hard for me to "NOT" buy one more!! lol
Sonny
aka
jet22b
Old 04-19-2015, 09:02 PM
  #127
Looks great Super08.
Old 04-19-2015, 10:41 PM
  #128
Super08's Avatar
Thanks, here are a couple more of how I did the flying wires. I used a Sullivan kit. The fin is all balsa so I drilled a 3/16" hole and then cut a piece of CF tubing to go through the hole and sit flush with the surface on both sides. This way it wouldn't crush the fin when I tightened down the brackets. The stab has hardwood so all I had to do was drill through it. On the fuselage I just used the two forward screws that hold on the tailwheel. I do a lot of racing around with a friend is why I decided on the wires. I didn't want to risk getting flutter and ripping off the stab.
ID:	2090349   Click image for larger version
ID:	2090350   Click image for larger version
Old 04-20-2015, 09:49 AM
  #129
Super08's Avatar
All completed now. My balance came out at 4.75" without moving or changing anything from how I assembled it so that is the way it will stay. The weight ready to fly less fuel came in a little heavier than I expected at 14 pounds even. Hmmm I may have to put my DA50 in this down the road. I will see how it performs first. To swap engines I could remove the ignition battery and it should come close to balancing with a 50cc. I could always move the main battery back into the rear fuselage behind the servos if needed. The DLE 35 has pretty good power though, far and above what the original 30 had so it should be fine. But if my buddy starts kicking my butt the 50 is going in.
Here are a couple of pics I just took outside of it and two of my shop. Don't laugh too hard I am addicted bad.....
ID:	2090481   Click image for larger version
ID:	2090482   Click image for larger version
ID:	2090483   Click image for larger version
ID:	2090484   Click image for larger version
ID:	2090485   Click image for larger version
Old 04-20-2015, 10:21 AM
  #130
Super08's Avatar
I just checked and my Giant Stick with the DA35 on it is 13 lb 9 oz and it flies fantastic so I am sure this one will be fine at 14 lb.
Old 04-20-2015, 11:14 AM
  #131
I t looks great, cant wait to here how the first flight goes. When I rebalanced mine its weight is now 13 lbs 15 oz , virtually the same. It has more then enough power for me, pulling straight up with out end. Not as fast straight and level as I thought it would be. I did find out between the two props I have had on it a 20x8 Top Flight power point and a xoar 20x8, with the xoar it flys with much more authority, seems to have more power with it. Now after saying all that my motor hasn't even gone thru a whole gallon yet, so I expect to gain some as more fuel is run thru it.
Old 04-20-2015, 11:42 AM
  #132
Super08's Avatar
I have a Falcon 19x10 on the way for mine. I am going to run a 19x8 for the first few flights to lessen the load on the engine until it loosens up a bit.
Old 04-20-2015, 12:42 PM
  #133
Lifer's Avatar
My comparison of Xoar vs. Top Flite props is the same. Xoars are simply better.
Old 04-20-2015, 05:14 PM
  #134
Indiomike's Avatar
Must agree. IMO Xoar if far better than Top Flite.
Old 04-20-2015, 05:49 PM
  #135
Super08's Avatar
Now you need to try Falcon.
Old 04-21-2015, 12:22 PM
  #136
jet22b's Avatar
Super08;
I love the flying wire you did on the tail!!! Now if you have too many planes in your hangar, I be more that happy to lighten your hangar stock!! lol
Sonny
aka
jet22b
Old 04-21-2015, 01:17 PM
  #137
Indiomike's Avatar
I have not tried a Falcon prop but I will. Where do you suggest I order one from? I have been satisfied with Xoars for quite a while. I tried Vess and although they are efficient props, they are also very fragile. I occasionally use an APC prop but I don't care much for their looks. I have not tried any carbon fiber props as they cost too much. I will give Falcon a try.
Mike
Old 04-21-2015, 01:41 PM
  #138
Indiomike's Avatar
I did a search and it looks like Bob's Hobby Center is as good as any to order from. Just ordered two 17x6 beechwood props. $34.00 shipped. I'll try these out on one of my DLE20 planes. I'll order a 19x8 for the DLE35 if happy with them.
Mike
Old 04-21-2015, 04:46 PM
  #139
Super08's Avatar
I switched most of my planes over to Falcon over the last few years. Their CF props even out perform Mezjlik and their wood props will out do a Xoar. My friend and I compared a 27x10 Xoar in the air with the same plane and engine to a Falcon 27x10 one day. The difference side by side was shocking. I couldn't believe the difference in vertical pull. I would pull away from my friend with ease. I still run some Xoar laminate props but they are getting hard to find.
Old 04-21-2015, 06:38 PM
  #140
Super08's Avatar
Ran my 35 up for the first time in the driveway today after putting in the battery that I was waiting to come in the mail. The needles are set very close to the recommended factory settings. Low idle is at 1600 and high idle set at 1900. Top end with a Falcon 19x8 CF is 7700 with only a couple ounces of fuel through it. It won't be long before I will have to switch to the 19x10 to bring the rpm down a touch.
Old 04-21-2015, 07:10 PM
  #141
My Feedback: (27)
Well the OS 33 is out, sitting at an angle the Pitts style muffler sticks outside and would require lots of cutting on the cowl. The header and bolts would not clear if mounted verticle as it's on the short side of the firewall.
Valleyview is out of the DLE 35's so a slight delay. Oh well had a ball flying my ultra stick today............
Old 04-21-2015, 07:23 PM
  #142
Tower hobbies has them 349 and use the coupon code on the front page get 30 off that and free shipping i think. 319 isnt bad
Old 04-21-2015, 07:37 PM
  #143
Super08's Avatar
That was exactly my concern with the 33. I am glad I went with the 35 then.
Old 04-22-2015, 07:29 AM
  #144
My Feedback: (27)
Too bad OS didn't offer a more user friendly muffler?????
Old 04-22-2015, 11:48 AM
  #145
jet22b's Avatar
Hey Guys;
On my maiden flight I use a Xoars 19/8 prop and the plane did okay. Did not know what the RPM was, so, I just ran the engine outside of my shop. the on-board and hand held tach read the same, low end was right around 1601 to 1603,
top end was at 7650 rpm. I just found Flacon website and I will try some of their props. All the gas heads in my club use Xoars props.
Hope this weekend will have more good weather so I can have some fun!!
Sonny
aka
jet22b
Old 04-22-2015, 05:34 PM
  #146
My Feedback: (27)
Well the 35 RA is on it's way!
Old 04-22-2015, 05:40 PM
  #147
jet22b's Avatar
You will be happy with the DLE 35RA. Plus you don't have to do any major cutting on the cowling to fit it over the engine!!
Sonny
aka
jet22b
Old 04-22-2015, 07:19 PM
  #148
Super08's Avatar
Gizmo if you want I can take a picture of the bottom of my cowl for you.
Old 04-24-2015, 11:25 AM
  #149
My Feedback: (27)
That would be appreciated a bunch!
THANKS
Old 04-24-2015, 04:39 PM
  #150
JoeMamma's Avatar
Spotted this Escapade a few months ago and thought it would be a nice addition in my hanger.
Had some Tower gift certificates from Christmas and super saver coupons so it appeared I could pick it up at a reasonable price.
Went to Tower website and discovered another Escapade shipment wont arrive until late July ! Could this be due to the “Slowboat From China” syndrome?
Anywazzz, I got lucky as my local hobby shop had (just) one in stock so I scarfed it up.
Pulled everything from box. No visible damage, but covering is pretty loose so it will require the typical re-ironing and re-shrinking. Hey, I just thought of something.........she’s a female and she’s pretty good at ironing. Oh no, did I really say that !
One thing that jumped out at me was the very limited rudder throw. With the pre-installed hinges it’s only about 2 inches on each side. With my flying style I was thinking more like 4 inches on each side. Still haven’t made up my mind yet about a power plant.
Joe M.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
