Fly Model 30 cc THunderbird
I just bought a flymodel 30 cc thunderbird that is NIB and would appreciate any feedback on the bird, especially what engine you used and how the bird balanced. I was thinking bout either a vvrc 40 twin or a dle 35 ra depending on the cg. I would rather not add any lead on either end. I would add a link but the site says I cant untill i have had 10 posts.The plane is at Rcjetsworld.
I haven't built that plane, but so many of these "China built" planes are so similar, I think it safe to say you could build it with either of those engines without worry about adding ballast. The trick is to do a CG location mock up to see where "stuff" needs to go about 1/2-3/4 of the way through your build. Installing the rudder servo at mid ship using pull/pull vs. mounting it in the rear with the elevator servos can make a huge difference in CG location, just like your battery locations.
1/2-3/4 done CG mock up = engine fully installed, including prop and spinner, wings completed with servos and linkage installed, and tail surfaces installed (but no servos yet). Assemble the wings on the fuse, set the cowl on top of the engine temporarily, set the canopy on the wing, and check your balance. At this point, screw the plans! Move the rest of your stuff to get the plane to balance as desired (usually on the wing tube). Been building this way for quite a while now, and have not added 1 once of ballast to any plane since adopting this practice.
Thanks for the advice, just got the plane today and I agree totally with your advice. It did come with a pull pull set up for the rudder and the tail can be assembled with one servo for the elevators, im not a 3d guy but id like two servos on the elevator
Yes, exactly. Use your mounting options wisely, with final CG location as a priority, and never add ballast again! My latest, a 30cc Skyline Edge I completed about a month ago, came in at 10lbs 2 oz. That's SUPER light for a plane of this size and power! In sorting it out/getting to know it, I find it's right on the borderline regarding my preferred CG, so I may end up moving the rudder servo to the rear and relocating the battery (again) before I'm all done messing with it, but that's no big deal. I will not need to add any weight!
Best of luck! -Al
Best of luck! -Al
