Kangke Waco Biplane
#377
My Feedback: (15)
NY
RE: Kangke Waco Biplane
ORIGINAL: l.wilber
Man oh man is that a sexy airplane. Maybe offer some different colors or even ARC. I wish there were more ARC's out there. I don't like my plane looking like the other members... but I don't have time to build. You choose your favorite covering and cover as you like.
#378
My Feedback: (98)
I took my WACO out today, it's powered with a Saito FA170-R3. The engine is perfect for the plane, and the plane can be flown by anyone that can fly a Sig Kadet. At 15 pounds this plane flys like a very light plane, being a bipe when you cut the power it comes down, but it can be slowed to a crawl. I have two servos in the bottom wing, 90oz, driving the top ailerons with slave rods, great roll rate, way more than is need for "realistic" flight. The rudder is very powerfull, great wing overs and knife edge flight. I wish I had put a bigger tank than the 20 oz. one I have in it, the Saito sucks it dry in about 10 minutes, even though I'm flying it at about half throttle most of the time, at full throttle the plane will hover, but if I wanted to hover I'd fly a heli. I found the LG to be fine, not too springy or stiff, I have no extra bracing on it.
I LOVE MY WACO!
I LOVE MY WACO!
#379
I have four flights on mine as of yesterday. This plane is outstanding . Does everything I have asked of it. Great knife edge, Four points, inverted, rolls, spins, ect. ect. and lands slow. What more could you ask for ? I'm very happy with this airplane. As soon as I get more stick time I'm gonna really ring this plane out. Harris smoke system bellows out smoke like crazy. 20oz tank lasts about 4min continious. Off and on will last the whole flight. I'm using the stock tank for Gas. Hitec digitals on everything except throttle. TAURUS 3.2 for power . And the vertical is OUTSTANDING. Weight is 16.5 lbs dry. I'm sure this plane will hover at less then 1/2 throttle. I have used the B&B set up for the landing gear (a must). And I'm running a BELIA 22/8 carbon prop. 6800 rpm's pulls like a tractor. Forward speed is NOT overbearing with this prop. I did try a few other props but the BELIA won out. I did realise that any prop I tried that had 7000rpm's or greated did NOT fly the airplane as well as the power props. And I tried a few!!
Happy flying to all.
AL.
AL.
#380
My Feedback: (135)
MA
Rich,
We must be connected mentally.
Same set up as yours except for 4 servos in wing, Saito 170 Radial and.....the car is packed and I'm on my way to the field for the maiden. Thanks for the encouragement!!!!!
Bob
Bob
#382
My Feedback: (135)
MA
Bad news Rich,
Had to do a go around on the first landing but the engine had dropped a cylinder. Throttled up and tried to climb but stalled the plane. Kicked over to the left and nosed in. It's banged up pretty good but its repairable. ent both wing tubes. The top of the fuse is toast, plywood formers behind the firewall are broken, had battery packs zip tied to them. Gear plate got ripped out along with the lower wing bolt plate. Stringers behind the cockpit are broken.
#385
My Feedback: (15)
NY
I baught the Beige Waco way back and been so busy haven't had time to finish it yet... Just finised the Paint... Painted Chocolet Brown Trim / edged with Gold Trim 3M tape... ( showed it to a couple friends and they were suprised how well the paint job came out.) If any of you decide to paint with Latex look it up here on RCU, there is a guy who gives exact mesurments for mixing the paint / FLowtrou / and water ... Paint went on perfect! I have a Brisen 2.4 40cc gas to put on it. With the pits wrap around pipe. Any sugestions of mounting the motor... ( did any of you use Vibration dampening mounts).
Saw the red and silver Waco at an Funfly airshow this weekend guy didn't fly it... Made want to get mine done. Will be finished hopfully next week...
Any problems you guys had or tips fill me in....
I've read the thread but it's long... LOL easier to be lazy and say HELP!!!
Later All!!!
Later All!!!
#386
Thought I would post some pictures of my waco it has a us 41 in it and flys just great I am having so much fun with this plane that I can hardly wait to fly it again
#388
My Feedback: (15)
NY
I'm using a Brison 2.4 40cc gas engine... What did you guys use for engine standoffs... I'm almost ready but I have to use between 1/2" - 1" offset to get it out far enough. Looking of line but want something easy to use. Thought about ply as last option is someting else is'nt better... Any sugestions?
Thanks Lee
Thanks Lee
#389
My Feedback: (98)
Mine with a 170R3 didn't need anything for a stand off. You know you use the cowl to adjust for engine length? The cowl is constant size and can be moved for and aft for adjusting for different engine lengths
#390
FL
How tolerant is this plane of HEAVY engines? I'll NEVER fly 3D, just standard aerobatics.... I have a SuperTigre 4500 that needs a home.... it's been converted to gas and all-up (mount, muffler, ignition) weighs about 4.5 maybe 5 lbs....
#392
My Feedback: (15)
NY
ORIGINAL: soarrich
I am using a Brison 2.4 with a pitts muffler so I need it forward a bit for the pipe to clear. I did some searcing on RCUniverce and found that most are using 1 1/4 in OAK Dowels cut and drilled to length.
#393
FL
"My waco has a us 41cc and flys just fine as a matter of fact I had to put some weight up front to get to balance."
What's the all-up weight of your US41 and how much does your completed plane weigh?
#394
My Feedback: (15)
NY
Just trying to finish up my WACO... I have one of the early kits ... NO Instructions. I downloaded them from the net. Most is done... found all the holes for mounting things, but what screws did you use to hold the Wings to the struts? Silly but can't tell by my instructions... Wood screws look too small... Black ones wont work unless their is a threaded peice inside... Aaagggggggggggg Help... Thanks...
#396
My Feedback: (135)
MA
Bull,
There are blind nuts in the wings for the strut bolts. You should have a bunch of 3mm (120") diameter ones about 5/8" long. (Approx.). They look like 4-40 capscrews but the threads are finer.
Bob
Bob
#397
My Feedback: (15)
NY
After sitting in my closet since last Augest Finally got started the Waco and it's finally getting to the last steps. Wings are painted. Wing servos installed. Pull / Pull installed. Brison 2.4 is mounted / Bisson Pitts muffler mounted. Only had to trim down the botttom of the fire wall 1/4" to get the pitts muffler to fit. Covered the area where muffler sits with aluminum shielding. Used oak dowels for stand offs on the engine. Trimed the cowl. Only thing left is puting the B&B reenforcment on the landing gear ( I had the 1/4" but the Wire seemed so big decided to order the 3/8 version will be here Monday or Tuesday ( trying to keep weight down). Bolt on the wngs... Mount the wind sheild. Recheck & LOCK TIGHT EVERYTHING!!! Then Zoom zoom zoom.....
Don't have smoke yet... Really want to add it, but funds are short so hoping next month I can get a system.
Almost there and sooooooo far to go.... LOL
#398
My Feedback: (15)
NY
Couple pics of my Waco... Since the pics I have all the struts done... All harware done. Landing gear done including B & B reenforsments. I still have to mount the wheels & pants. Paint inside of pilot area. Mount pilot. Snoopy Head! Go back through Lock tight everything... Balance and set throws.
#399
My Feedback: (62)
UT
Sad to hear that Jimmy Franklin was killed in an airshow accident July 10. My Waco done up in his markings will keep on flying in his honor. We'll miss you Jimmy.
#400
My Feedback: (15)
NY
Finally after soooooo much time... got my first flights on my WACO... Absolutilly GREAT.... Need a few clicks of Down elavator but other then that was perfect. I need to change the wing incidence and put just a little more neg in it. Very please with this plane. Take offs were some of the smothest I've ever done. landings were just as nice... Love the Brison 2.4 works well with this plane. Got six flights on it Thursday and will get a few more tonight... After flying a bunch were over taking a look... I built the beige one and painted it so most didn't know what it was. Ohhhhh soooooooo nice...
