Reload this Page >
Flaps on Great Planes Cessna 182
Old 03-20-2006, 05:20 PM
  #51
huminski
My Feedback: (23)
huminski's Avatar
Default RE: Flaps on Great Planes Cessna 182
Hey,
Looks good!
Just a note, you really didn't have to strip the wing. I sent mine right through the band saw, covering and all. I then just recovered the trailing edge of the wing and the leading edge of the flap. Same deal with the servo hatch, cut out the square and left the covering in place.
But you're obviously having more fun than me!
Old 03-20-2006, 05:21 PM
  #52
huminski
My Feedback: (23)
huminski's Avatar
Also, glad to say I have finally put the maiden flight (and six subsequent flights) on the cessna (only took 3 years!!!).
Flies great. Flaps have the same effect as they did on the top flite 82" version I built. You will need to mix in down elevator to get it to avoid balooning up when you deploy them.
Nice slow passes over the runway with the flaps down.
Have fun, post more pics when you get more work done. I like how you went even more scale looking than I did, rounding the top leading edges. Nice.
Old 03-21-2006, 01:47 AM
  #53
steve2972
I Stripped the whole of the wing as I`m recovering in a different scheme.I`ve also completly stripped the fuselage too!
Will post some more pics as I go.
Glad that she flew well with flaps deployed.What % of down elevator did you mix in- 12-15%?
Cheers
Steve
Old 03-21-2006, 07:16 AM
  #54
huminski
My Feedback: (23)
huminski's Avatar
I have not done the mix yet so I have no idea. I know that at full deflection which was probably about 70 degrees of flap, the plane shot into a straight vertical climb and stalled. I was just doing this for testing at about 4 mistakes high, it was way too much flap for normal use but I just wanted to see what it did.
I have a JR 378 radio with the flap switch that is like a digital trim (beep beep beep) and if I deployed them one beep at a time while also slowing the plane down, it flew good enough that I probably won't mix in down elevator. I only used about 45 degrees of flap at the most for actual slow passes and landings. Did not try them on takeoff but maybe next time.
If you are going to slap them down quickly just be prepared to keep it from doing an impromptu stall turn.
Old 03-22-2006, 01:37 AM
  #55
huminski
My Feedback: (23)
huminski's Avatar
new avatar test
Old 04-21-2006, 11:48 PM
  #56
bldrums
bldrums's Avatar
Huminski
I am buying the GP Cessna 182 and definately want to add the flaps. Can you make the pics available again? ( they are off the post now ) I would really appreciate that !
Thanks , Bill
Old 04-22-2006, 05:41 AM
  #57
Primodus
My Feedback: (56)
Primodus's Avatar
Bill, the pics are on page 2 of this thread. Good luck with the mod, it is very easy to do. It adds a lot to this model. I did it on mine in about an hour.
Old 04-22-2006, 10:46 AM
  #58
bldrums
bldrums's Avatar
Premo, Thanks, got it!
Bill
( now THATS a Cessna 182, nice work )
Old 05-21-2006, 07:32 AM
  #59
rwright142
rwright142's Avatar
I also want to thank everyone for their replies. I want to add flaps as well. My question is about the connections to the receiver. The attached pic shows the layout of the radio and receiver and the inputs. I want to make sure I get this right:
Channel 1 is for connecting the right flap and right aileron. I assume this is down with a "Y" splitter? Channel 6 is for the left flap and left aileron - "T" connector. I'll use the "Flap knob" since there is no 3 position switch and will also config the Elev - Flap mixing.
I think I got it. If I have missed anything or need correction please let me know.
ID:	464413   Click image for larger version
Old 05-21-2006, 07:35 AM
  #60
Primodus
My Feedback: (56)
Primodus's Avatar
Use a Y-cable for both Ailerons and Flaps, but put both ailerons on channel 1 and flaps on channel 6.
Old 05-21-2006, 11:02 AM
  #61
rwright142
rwright142's Avatar
Gotcha, that makes more sense then how I was reading it. Boh ailerson connected with a "Y" to channel 1, flaps connected with a "Y" to channel 6.
Old 05-25-2006, 05:19 AM
  #62
rwright142
rwright142's Avatar
One more question:
Will this servo work for the flaps? ($9.99)?
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXUK84&P=ML]Tower Hobbies TS-53 Servo S3K Standard U[/link]
Will ths Y-Harness work? ($9.99)
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXL307&P=ML]Hobbico Y-Harness Futaba J"[/link]
Old 05-17-2007, 12:52 AM
  #63
steve2972
Its,been a while,but here`s a couple of pics of my Cessna complete which show the flaps etc.
ID:	685974   Click image for larger version
Old 06-04-2007, 04:58 AM
  #64
steve2972
Test Flew the Cessna yesturday,flies great!
Its interesting and I`m aliitle puzzled as there was no pitch change with flaps deployed.I had 2 settings,10% and 30%.Plane comes in nice and slow.The plane flies scale on the Saito 56 although not overpowered.
Steve
Old 04-27-2011, 06:52 PM
  #65
3739
Can anyone tell me how to program my futaba 7cap radio so that I can grt my flaps to work on the G switch?
Thanks Bob
Old 04-28-2011, 01:32 AM
  #66
Kostas1
Kostas1's Avatar
ORIGINAL: steve2972
I like so much the colour!
Is this scratch built ?
Old 01-27-2014, 06:21 PM
  #67
jlask
there is an error on those photos (page 2). Is there any way to see how you've done it? thanks in advance..
