ModelTech Giles-202 (CG)
Anyone know where the CG is on the ModelTech Giles-202 .60 ARF?
I just bought this used and I don't where to locate the CG.
FL
I am sure I have the restriction(i mean instruction?) manual at home. What a nice looking plane. I had two, both snaped uncontrolably.Both lost. I gave up on the Giles and now fly a GP 160 size Extra 300, much more forgiving ( but will snap if pushed!!) I will try to post cg tomarrow if you dont get it sooner
FL
I got the manual
c.g. 4-3/4" back at fuse side.
and as i said watch the snap. the elevator throws are very importainand are
1/2 inch low rate.---- 3/4 inch high rate
I think mine even snaped at the top of loop on low rates.
Good luck Scott B.
Good luck Scott B.
