 SA 30 Waco setup ? >
SA 30 Waco setup ?
SA 30 Waco setup ?
Old 04-16-2004 | 09:12 PM
Default SA 30 Waco setup ?
I'm starting with the recommended throws and 45% expo everywhere should I be expecting a squirly first flight ?
With a GMS 32, MA 11-4 ,Slimline Pitts 600MA nicads and HS 80s on all surfaces - seems very light for a bipe should be a "lively little critter".
Old 04-17-2004 | 12:36 PM
planebuilder66's Avatar
My Feedback: (8)
Default RE: SA 30 Waco setup ?
Great little biplane, just make sure the wing incedencesare correct. Top- -1 deg, bottom 0 degree, tail 0 degree. I flew mine on the magnum, it had scale like performance, a hot .30 size 2 banger would be a better choice I think. I had a sad ending to mine, the flash 5 transmitter I was using decided to turn off while in flight, it turned out to be a bad switch in the controller. strong little plane thou, it went in at full throttle and when I went to pull it out of the ground, the firewall and motor were still attached. The cowl got pushed back to the cabanes but the nose never broke away.
Old 04-18-2004 | 09:24 PM
Bummer about your Waco - I'll double check the incidence.
Jim
Old 04-18-2004 | 10:54 PM
forestroke's Avatar
While I never flew a WACO, I had a WM Ultimate 30 and if I had a word of advice, I would say two things.
Firstly- I would make sure the CG is on the nose end of the range. A few millimeters difference on such a small and sensitive plane is the difference between a gentle flyer and a crazy circus act.
Second - Don't prop it for speed. I had a 32sx with a 9 x 7, recommended by my friend at the field over my original 11 x 5. I can say it flew terribly with the higher pitched prop. But regardless of prop... fly her slow, first... otherwise she will bite.
In terms of flying, you shoul definitely have a spotter and fly on a calm day. I maidened on a cloudy, windy and gusty day and I couldn't tell if she was upside down, going away or toward me and almost lost her multiple time. Couldn't get her grounded because her CG was so far back that even at half throttle she could maintain a knifeedge with no rudder input. Scariest thing that ever happened to me was to have a plane that WOULDN'T come down!
Anyway, none of this is the least bit scientific... just my experience. Good luck with your WACO.
By the way, I saw a WACO the other day, I wasn't impressed with the finish, it is my LHS or are all the WACOs finish not so clean?
Old 04-19-2004 | 12:26 AM
My Feedback: (31)
I have one of these still in the box waiting for its day to come. I'm looking forward to your flight results. I have heard from others its a good flyer, but to make sure you get the CG a little forward at first.
Duke
