Great Planes Little Toni firewall issue
MA
Hey all... I am thinking of getting the GP Little Toni. Has GP fixed the weak firewall issue which I read about here? If not, how would you go reinforce that area. Are there other areas which need reinforcement?
RE: Great Planes Little Toni firewall issue
Most if not all firewalls need to be reinforced. I do it religiously on all my arfs. Also a plane has retracts, then the mounting blocks. Just get the plane. Check the gear mounting on the Toni. I wouldn't worry about it. I mix a combo of epoxy and GP milled fiberglass. Saves the use of cloth and holds up good. Sand the corners a bit and slap it on their -inside and out.
