Cermark Javelin II - Building & Flying
RE: Cermark Javelin II - Building & Flying
Hi Tommy,
Thanks for the information. Good points that you make. I know about starting planes (your J-3 started in 1983) - I had a similar situation.
I have an Irvine .46 in the plane right now with an 11x6 prop. It hasn't seen any air under the wheels yet - I just have a few minor tweaks and some balancing to do, and it'll be ready to go. I want to put some Ultracote 'slashes' on the bottom of the wing for visibility.
If we ever see Spring up here in the Northeast, I hope to perhaps put it into the air on Monday. I haven't weighed it yet, but I built it pretty much stock - the only change was to put Sullivan clevises and control horns on it.
I'll bear what you say about the landing pattern. I have heard that from other sources too.
Thought I'd post here instead of starting a new thread. I dorked my Javelin on a crosswind landing []and I have to repair the firewall and remount the engine. In the process of doing this I stripped the threads on one of the bolts that attaches the engine mount to the firewall and messed up the threads on the blind nut as well. I'd like to retap the blind nut to clean it up and buy some new bolts. However, I don't know what size bolts these are. They seem like an 8-32 but not quite. Maybe they are metric? Can anyone help identify the size of these bolts? Again, they are the bolts that attach the engine mount to the firewall. Thanks
Thanks Bob. I took a bolt to the hardware store and an 8-32 nut fit almost perfect, so I retapped the blind nut and will use an 8-32 bolt.
