HARMON ROCKET
#151
RE: HARMON ROCKET
Just got mine yesterday and am glad to see so many guys enjoying the plane. Got a JBA Engines .56 with it. Have not seen anybody use this motor is it fine or should I look for something else?
Cobus
Cobus
#152
RE: HARMON ROCKET
ORIGINAL: Hesco Racing
Cobus
Cobus
#153
RE: HARMON ROCKET
http://www.jba-engine.com/showProduct.asp?id=223
size disp(cc) bore(mm) stroke(mm) output(Hp/r.p.m) crankshaft weight(oz) prop size practicall range
56F 9.15 23.4 21.2 1.50/17500 1/4*28 16.5 11*7 2600/14800
The weight is lighter than the evo .46 but puts out a bit more power. Hope it's going to be a good one.
Cobus
Cobus
#154
RE: HARMON ROCKET
That should be fine. Mine zooms about the place with a supertigre .60. Make sure you brace the horizontal stabs and do something about the soft landing gear (wire braces between the les works fine).
#155
My Feedback: (14)
RE: HARMON ROCKET
well i have flown mine now with the TT Pro .61 on a macs header and pipe. Sounds awesome and really zings across the sky. I maidened it before switching out the gear and i think until i have problems i'm going to leave it alone. Sure it springs out some but it sure makes the landings soft!!!
Geoff
Geoff
#157
AR
RE: HARMON ROCKET
Although I don't have mine nearby to measure wing thickness (for sale at local hobby shop), I can tell you the HR3 has a very thick wing. Despite the thickness, it is quite fast and handles real world maneuvers of all sorts well, but is not a 3-D machine. It is quite easy to fly and easy to land.
If mine doesn't sell soon, I might keep the plane and install a 4-stroke engine.
