Hanger 9 Harrier 90
RE: Hanger 9 Harrier 90
Are you refering to a Hangar 9 model or the Seagull Harrier 90?
I'm not familiar with the Hangar 9 unit but if it's the Seagull one you're refering to, I have one fitted with a Saito 1.20 and it's a great machine - it goes exactly where I point it (which isn't always where I want it to go) and is a great training platform for Extreme 3D. I've got the CofG set in the middle of the recommended measurement (I can't remember what the measurement is though) and it flies every way from gentle on low rates (as recommended in the manual when I built it) to wild on high rates (which are as much movement as I can get)
ORIGINAL: aussiesteve
Leave it to me to butcher the name. <G>
Yep, I think that's the one. It is finished in transparent blue covering. Beautiful. I was thinking of trying it with the BME G90 gasser.
My Feedback: (17)
ID
I built one up last year. I used the YS110 in it. It weighed 8lbs 8ozs ready to fly less fuel. It is a pretty tough airplane. Very solid in the manufacure of it. I liked it a lot. Did the nicest waterfalls, of any plane I've flown. Basically just spin around the wing tube and stay at elevation without dropping at all. Pretty cool maneuver. Very easy plane to fly. I could do a decent flat spin with it but not as good as a UCD or Mayhem. Knife edge was poor on this plane. Seems like it should have been better with the flat fuse but I thought it stunk. The "harrier" maneuver is hard with lots of wing rock but with enought spoileron I was able to do decent harriers.
My biggest beef with the plane was knife edge flight and it is VERY hard to see. I put stripes on the bottom of mine and it helped. But it was still hard. Transparent blue covering. What are they thinking. Or are they not thinking.
Anyways, I liked the plane but I gave it away to a friend because I liked the UCD better and they were so similar that I didn't think I needed both.
Good luck.
Barry
Good luck.
Barry
