New Giant GP Super Sportster!!!!!
#551
RE: New Giant GP Super Sportster!!!!!
Patrick these are modified gears from a Super Stearman from Great Planes. The part number for the gear are as follows (GPMA2464 Great Planes Landing Gear Super Stearman .91 ARF)
http://www.greatplanes.com/airplanes/gpma1350.html
These are made of Aluminum and Fiberglass and weigh 610g with mounting block. Gear Dimensions H 20cm x W 38.5cm
Cheers
Steve
Cheers
Steve
#552
SBrian,
Super, thank you for the info. I have just received my new GSS in his limp and I tries to inform before beginning the construction. I am above going to put a OS 160 FX. By comparison to your model, I think that I should put off the Landing Gear. OS 160 FX is less heavy than your engine gasoline. Of what do you think of it?
Patrick
Patrick
#553
My Feedback: (120)
CA
Change the landing gear. You won't be happy with the gear in the wings. They will break at the mounts or bend and are a pain to transport.
Just my 2cents worth.
Richard
Richard
#554
The transport is easier if the train stands by the fuselage. For me this model is really more beautiful with the train under the fuselage, we could even believe that it existed....It is a tasteful question and tastes and colours, the world is needed for all. It is the charm of modelling
Patrick
Patrick
#556
MD
Check my posts on page 18 of this thread, post 430 and 432 are pictures of how I converted my GSS to fuselage mounted landing gear. It is a little work, but I think worth the effort.
James
James
#557
MD
The beauty of having a metal lathe is that I was able to cut a shoulder on the end that was soldered to the plate. I enlarged the hole in the plate before making the brass fitting so I would not change the volume of air able to enter to the diaphram, the shouder only extends into the plate the thickness of the plate. The diaphram is approximately 3/32 to 1/8 under the plate. I used low temp. Silver solder for soldering. I hope this is clear enough, it's much eaiser to do it than describe it. The plate was removed from the carborator for drilling and soldering. I will have more pictures soon.
James
James
#559
All the designers do not put the landing gear in the same distance of the partition firewall. Is it important ?
Patrick
Patrick
#560
My Feedback: (551)
Yes. It depends on where you fly. For hard surface runways, the rule of thumb is to put the axles directly under the leading edge of the wing. For grass fields they should be an inch or two further forward.
If the gear is set up for a hard surface it will tend to nose-over on grass. If is set up for grass, it will be squirrelly (unstable) during take-off from hard surfaces.
Jim
Jim
#561
Thank you jrf. I learnt something today. Our track runway is hard, I cannot put the train of Sbrian (In spite of it is very beautiful) but rather that of jben.
Patrick
Patrick
#562
MD
As promised, here are more pictures of my GSS, I made the blue and stars graphics today and installed them. I still have some minor things to adjust before the maiden flight, but is is getting close. I weighed the GSS and it came in at 15 lbs. It didn't feel that heavy, but I guess I have to trust the scales. If anyone wants a list of items installed on the GSS I will post it.
James
James
#565
MD
The gear is from an old CAP 232 1/4 scale by Hanger 9. As far as I know it is no longer available. There are probably better gears out there that would not have to be cut. The problem is most kit manufactures don't publish the dimentions of the gear.
Birman,
I'm working on the list now.
James
Birman,
James
#566
WI
Thanks-I just ordered a second GSS. Couldn't pass on a deal. Going to put a conversion engines on it and use it as a test plane, so i wanted to move the gear off the wing. I like the blue with stars, red-white and blue is always great.
#567
MD
Here is my list of equiptment installed in my Great Planes Giant Super Sportster.
Engine: Fuji BT34-EI Gas
Muffler: Fuji Standard
Ignition Module: Fuji
Transmitter: Futaba 14 MZ with 2.4 ghz module
Receiver: Futaba R6014FS
Servos: HiTec HS-985MG
Receiver & Ignition Switches: Fromeco Badgers
Receiver Battery: Fromeco Li-ion 2600 mah, with Fromeco Regulator
Ignition Battery: Fromeco Li-ion 2600 mah, with Fromeco Regulator
Ignition Cutoff: Smart-Fly Optical
Spinner: Included with GSS
Push Rods: Carbon Fiber constructed by me, with 4X40 hardware
Ball Links: Nelson Hobby 4-40 Heavy Duty
Kwik-Link: Dubro 4-40 Safety Lock
Propeller: JXF 18X10
Canopy: Attached with 2mm Button head socket cap screws
Fuel Tank: Hanger 9, 17 oz.
Added Graphics: Designed and cut on a Roland GX-24
Fuel Dot: PSP Mfg.
Tail Rigging: Sullivan Attachment Straps, DuBro Qwik-Links and 45 lb. Surflon Stainless Steel Leader
Tail Gear: Hanger 9
Landing Gear: CAP 232 1/4 Scale modified with Center cut out
As shown in last post, ready to fly less gas, 15 lbs.
If you want to see a chronological order of construction pictures here are the post numbers in this thread: 430, 432, 489, 531, 545, and 562.
James
Fuel Dot: PSP Mfg.
Tail Gear: Hanger 9
James
#570
MI
I installed a OS 1.60 in mine and it gives me unlimited vertical, I use all coreless high torque servos and a bison muffler, I mounted the engine sideways came out awesome, check out the pictures.
I also didn’t use the control rods that came with the plane, I went with a rod that was threaded on each end.
The Sullivan 4 40 rods are a perfect length, I also used their 4 40 golden clevises.
#571
MD
Marine,
Looks very nice, I have two questions, what is the brand name and size of your pilot, and what is the weight ready to fly less gas? Thanks in advance.
James
James
#572
MI
I have been flying mine for 2 years now with a 1.60 OS motor and I haven’t had one problem with the landing gear, now the 40 size arf sportster that was the first thing to let go, the 1.60 motor gives the plane unlimited vertical and I mean it climes out with authority, I can hang the plane on the prop at about ½ to ¾ throttle very awesome plane with the 1.60 in my opinion, but you better bring some fuel, I can burn up a gallon in a single day. Have fun fly safe and keep the rubber side down on landings. O wait I did get a hole in the bottom side of the wing last year from a wheel paint, easy fix but no problems since, and no it didn’t tear out the block, just pocked a hole with the back of the pant. I like the things, what I get for using them on grass I guess. But stay they will.
check out the pics of the wing and gear.
#573
My Feedback: (51)
I fly my Giant Super Sportster off grass as well, and my wheel pants are starting to look a bit shabby also after two years. For some reason though Great Planes/Tower doesn't stock the replacements like they do for alot of other ARF's. I did build a couple Super Sportster 90/120's from kit, and they had some pretty thick mil pants that came with them, and were at least as big as what is on the Giant SS ARF. I was just hoping to find some just like it has on it. Buying a set every two years isn't to big of a deal if they had them to buy.
#574
My Feedback: (51)
ORIGINAL: jben
Marine,
James
Marine,
James
I had to do a little hacking on my pilot to shorten him up a bit to fit under the canopy, but he looks right at place in there now.
#575
MD
Thanks for the information, have you weighed your GSS? If so what was the weight?
I have scanned this entire thread and didn't find any posted flying weights for the GSS, anyone that has weighed his GSS, please post the finished weights.
Thank you,
James
Thank you,
James
