Twist 3D 60 ARF
#351
Hi,
Got this beautiful plane. I'm impressed how easy is to build it.
I'm putting a Saito 115 in it, and will use a 16x6 in the maiden.
Is this a good choice of prop?
I'm going to use the plane as a 3D trainer.
Another thing I would like to ask is about a weakness some report at the middle of the fuse.
Has any one done a fix that can show some pictures about it?
Thanks in advance.
Thanks in advance.
#352
Hi,
Thanks in advance.
Thanks in advance.
#353
Good day
I'm putting together my TWIST 60 with OS engine GT-15cc. My question is do I need to do on this model, the tilt axis motor to the right and down? (or these angles are already set engine mount?)
#357
Wish I could be of more help, but I like both and each is fun. The 40 is quicker on high rates but both can make you wonder if you counted all of the rolls ...................... Both are I think easy fliers and easy to float in and land. Inverted is as stable as it gets.
