zdz 80 vibration
zdz 80 vibration
Oh - the 80?
Yep - they run smooth-
I have flown one in a 17 lb model - built originally for a 2.4 ci engine - very light construction- and --vibration is not a issue.
But then - the current purpose built engines - not converted chainsaws - all run pretty darn smoothly.
All of my new designs are much more lightly built than I originally thought necessary - simply because the engines don't try to tear em up.
The 80 single should work well on a airframe ready to fly including engine as light as 16 lbs -
Most of the damage I get -is from the f---in door jambs in my house.
NJ
zdz 80 vibration
Hey Dick, you had a post in the 3-D section on a very light airframe you were building a while back with an ultra low wing loading, how did it work out, and did you get to play with balast to see how much difference it made.
zdz 80 vibration
I am flying it each weekend since Oct - we flog it dog it and try all kinds of stuff with it - it is 19 oz ft loading and I can say with no reservations - that this is the way to go -
almost all ARFS for th 40 cc engines -on up -are close to 30 ox ft - we have flown plenty of that stuff- The difference from 19-29 oz ft -same power aprox same area --is extremely noticable
zdz 80 vibration
Not much to tell - weigh everything - look at rubber band model construction -don't worry about adding carbon fibre parts or drilling holes in engines - this stuff is all fine -but excellent results can be had using spruce and balsa - thats it.
Look at the current crop of good electric powered stuff- -weight counts !
My next big gasser will be the 20-300 Ultimutt-- at 2000 squares - and should be under 20 lbs - all up - no fancy stuff required .
foam flight panels with lite balsa skins - and an all balsa fuselage with some spruce stringers -and wire for gear and struts - - sounds awfully old fashioned -I know -but so far I have seen nothing which beats these materials in a usable weight to strength comparison
#31
NJ
zdz 80 vibration
Very cool, congradulations on your efforts! Keep us posted on the 20-300 it sounds like a winner. Do you by any chance have plans for the one your flying?
#32
IN
zdz 80 vibration
On the other side of the wing loading equation, I weighed two different Carden 33% Caps. Both with a DA-100. The light one weighed 30.5 lbs and the heavy one weighed 34 lbs (needed to carry 3.5 lbs of nose weight).
#33
zdz 80 vibration
No working plans - They are a real time killer for me -
I do an awful lot of sketching and usually redesign the whole thing a dozen times but working drawings have to be left for a completed model which will be sold to others.
#34
NJ
zdz 80 vibration
Originally posted by Diablo
On the other side of the wing loading equation, I weighed two different Carden 33% Caps. Both with a DA-100. The light one weighed 30.5 lbs and the heavy one weighed 34 lbs .
#35
IN
zdz 80 vibration
You are correct. It must have been a 35% Carden Cap - a little over 100" span. I get mighty confused about all these %s. Too much to keep straight. The heavy one was an older model with recessed wings - it had double wall construction for a lot of the fuselage. Looked like it was built to withstand an atomic bomb.
The point was the Carden Caps can be heavy when built stock - same with the Aeroworks 33% Edge 540-T. The AW Edge-29 lbs with either a 3W-100 or DA100 or 3W-80.
The lightest plane I've seen with a 100+ inch span is Dave Genovese's DR-109, just under 23 lbs with a BME 102 - no pilot, no frills.
The H9 33% Cap comes out just under 24 lbs with a ZDZ-80 - this gives it a lighter wing loading than the typical Carden Cap or AW Edge.
#36
zdz 80 vibration
#38
ON, CANADA
horizon
Reason why I ask is that on horizons website, in the sukhoi info, they say that this engine is a "shaker" and nuts and screws need to be periodically checked and tightened.
#39
zdz 80 vibration
I read that post - and was really surprised -
having done a number of H9's for me and friends - we found this to be NOT the case -
Guys flying twins here, have as much problem with this as anyone -
Here is the "but"
we all use a 4/40 bolt - with a washer and a tiny piece of neoprene fuel tubing as an extra washer -- this rubbber washer squeezes down and stops loosening. and the cowls are the worst offenders as this is a pretty cantilevered load
The shaking we have seen on these engines is from the idle adjustment on the carb- If rich - too rich - the engine hammers - this is NOT engine vibration from being an unbalanced single - it is simply a harsh power stroke.
A twin setup incorrectly will do the same thing.
Horizon's ZDZ 80 engine has the earlier Bing carb - which is typically not as easy to get smooth at idle --as the Walbro- But again - this is a case by case affair.
You will never eliminate power pulses in a single pulse per rev engine design - single or twin- makes NO fu--- difference.
Run a few of em if possible and you will see what I am driving at.
Here is the "but"
#41
My Feedback: (7)
zdz 80 vibration
Come on Dick, don't be selfish, how about this light airplane, I have a ZDZ 40 which will be doing nothing very soon and I like your concept........
#44
NJ
zdz 80 vibration
No I didn't, I keep the planes at my fathers house and with the cold weather I just haven't had a reason to go there. Today is the first day it was over 25 degrees since november.
#46
My Feedback: (8)
WA
zdz 80 vibration
Aerografixs,
Dick isn't kidding. He sketches the outline on a piece of masonite or MDF then just builds from that. I always bug him about plans, and I think his new lightweight Petrol Petrel (the plane he is talking about) would make a fantastic electric conversion. It is FAI Pattern legal (sub 11#, 2m wing, 2m fuse). Coupled with the 32# static thrust of from his piped ZDZ 50 it is truly an amazing plane. It will take off in a few feet, transition to vertical, and disappear. The best thing is, it lands like a sailplane. It just floats and floats...Dead-stick is not a worry at all.
In fact, I was going to buy it before I decided to go larger (sorry Dick!). See my Wild Hare Giles in my avatar.
Dick is the king of light planes. He built a Hangar 9 Extra (see my avatar, yellow plane) for my dad, and it weighs just over 22# with a piped ZDZ 80 on it. Most people think it has a DA or 3W twin in it, it is so smooth. In fact, most of the people I fly with tell us the ZDZ 80 isn't enough engine for the H9 planes -- that is, until they see the Extra fly.
Brett
Brett
