 Anyone had this problem? >
Old 09-25-2006 | 04:18 PM
FenderBean's Avatar
Default Anyone had this problem?
I have a Great planes christian eagle 2 and the wing saddle is tight, so tight in fact when the wing is bolted on it rinkles the side monokote for the wood bending. I have also noticed that the fron wing dowls have burnt marks from where they set in the holes. Then last night I noticed the glue joints around the saddle area are coming lose. The plane has about 6 flights on it and im runnning a Fuji 50. So any advice on this maybe a solution to fix it. I had another one that i sanded the saddle but then u lose the wing dowl tight fit. The wind down holes in the fuselage are oval so I guess u can get the wing on, and that leaves no support on the top part of wing dowl. This meansthe wing saddle is keep the wing dowls pressed against the bottom part of the hole.
