Reload this Page >
CMP Cessna 182 Building Thread-->the best scale Cessna 1.20 size ARF that is on the market!!!
Old 01-07-2020, 07:24 PM
  #1276
bearcatt1
Hello, I'm not sure if you received info for the wing tube, but I can get it for you on Wed. I have a n.i.b. model on the shelf that will begin assembly on floats.
Old 01-07-2020, 07:54 PM
  #1277
[email protected]
Thank you bearcatt1,
unfortunately I have not been able to get any info from Anyone. I appreciate your help. I measured the. Inner wing socket at 19mm, but I'm afraid that a 19mm tube would not fit. It around be very snugg.
again thanks for your assistance.
Best
Lionel
Old 01-12-2020, 06:56 AM
  #1278
[email protected]
Bearcatt1,
Did you get a chance to measure the wing tube?
Lionel
Old 01-13-2020, 07:45 PM
  #1279
bearcatt1
I sent an email, but here's the measurements
Main spar - 19mm x 600mm inside wing dia. 19.48mm
Tail spar - 10mm x 300mm inside wing dia...11.41mm
this was measured with a digital caliper...
Old 01-15-2020, 03:11 PM
  #1280
[email protected]
Thank you Bearcatt1!
Appreciate your assistance.
Best
Old 09-16-2020, 10:43 PM
  #1281
zxxflyer
Default ...it's been a lonnnnnnnnng time.
static display no longer....
Hello again to everyone. Here is a sneak peak of the build. It's back in progress after hanging around as a static display for long enough.
Old 09-28-2020, 06:50 PM
  #1282
JIMBOMCK1
I have a CMP Skyline ARF, I purchased at an estate sale 4-5 years ago. I discovered the rudder was missing, so the build was set aside. Now with the Covid 19, I need something to do, situation, out it has come. Yes, the rudder is still missing. I need some insight, or ideas on tracking one down. I could also benefit from a build manual also.
Any assistance will be appreciated.
James
Old 09-29-2020, 06:11 AM
  #1283
DragonLines
My Feedback: (13)
DragonLines's Avatar
Hope this is what you need. These have been out of production a long time so a rudder will be hard to come by. May have to build your own. Good flyer just be sure and re-enforce the servo mounts. Old planes the glue lets go.
File Type: pdf
Old 09-29-2020, 06:15 AM
  #1284
DragonLines
My Feedback: (13)
For some reason the site won't let me upload the main book. Drop me an email and I will send it to you.
Old 01-10-2021, 10:12 AM
  #1285
Multi-Engine Guy
James
. If you haven't already created your own rudder, I would suggest trying.
I have the CMP 182 40 size. But, I believe that all of them, the 40, 50 and 120 sized ones just had a solid balsa rudder. The only difference was that the 40 sized one didn't have the scale details added.
