Reload this Page >
Jerry's Big Boy ARF servo linkage opinions
Old 01-30-2007, 09:41 PM
flygilmore
flygilmore's Avatar
Default Jerry's Big Boy ARF servo linkage opinions
I have read all that I can on here and still undecided on the 4 servo wing setup. My question is, can I simply use two y-harnesses for the ailerons (and plug into channel 1&6 for flaperon use) knowing that my servos will be slightly off from one another or do I need to use two futaba sr10 servo reversers to fine tune each pair per wing half. I know that the sr10 would be ideal (and I plan on using one for the two elevator servos allready) but at $35 each I would be buying three. I have used the sr10 before and it worked great, however, I realize that this isn't a precise flying plane and perhaps would be acceptable to use the cheaper way. I will be using 4 futaba 3010's for the wing, two for elev. and undecided on rudder as of now. Please, those who have experienced this planes setup, give me some guidance.
thanks!
Old 01-30-2007, 11:11 PM
TigerTail
TigerTail's Avatar
Default RE: Jerry's Big Boy ARF servo linkage opinions
That is exactly what I did. Both servos in each wing are connected by a Y harness and then plugged into 2 seperate channels. Adjust the linkage carefully and it should give good results. The big JBB thread will give you lots of info on the setup of this plane.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
