Whats a nice Electric plane for a 600 sise motor
Ive got some bits lying around at home not doing anything
Items i have:
8.4 v 2800 mah pack 400g ( cheap one from china ! )
8.4v 600 motor + 8 x 4.5 prop (Probably geat away with 9 x 5 Ungeared)
4 channel Liasing Reciever Cheapest one ive ever seen (700 -900 meter range)
Jeti 35 amp ESC
3 Mini Servos and standard size ones
Hitec focus 4 TX 700mah batt
and would like some sujestions for a cheap airframe as im on a budget ( Would prefer ARTF but would consider a Kit if its cool enough)
So far ive only seen the Ripmax Easy street as a suitable option
But also if i gear the motor say 2.8:1 i will be able to swing a bigger prop say 12 x 7 inch and power a bigger sise plane
Any sugestions ?
Jim
UK
Items i have:
Jeti 35 amp ESC
Any sugestions ?
Jim
UK
RE: Whats a nice Electric plane for a 600 sise motor
Jim, what kind of plane are you looking to fly? sport, goldeage, warbird, etc. Also seems from what you have you'll be able to fly about a 3lb. plane?
Regards, Jack
Regards, Jack
I would like it to be a 4 channel Trainer / sport aircraft capable of basic aeros like loops stall turns and rolls ,
(not 3D though)
I like the shape of the ripmax Easy street
and also the E3D (but i think this one requires a lot more power !)
So some thing shaped a bit different from what we are all used to IE Warbirds , Cessana ETC
