Reload this Page >
H9 1/4 cap 232-gas tank installation????
Old 02-16-2002, 05:51 AM
flynm
My Feedback: (24)
Default H9 1/4 cap 232-gas tank installation????
Hi Guys,
I need some help on gas tank installation on my h9 cap 232. The tank fits tight, did you protect it from vibration? Also the tubing is very close to the firewall, any suggestions?
I put a Saito 180 in mine. The tank is well below the carb needle valve. Will this be a problem or does the engine have enough sucking power?
Initially I put a fueler in the cowling, but could seem to prime the engine any hints???
Right now I have three lines coming from the tank. One to the engine, one to the muffler, and one hanging out of the bottom of the cowl with a screw in it. The last one (out of the cowl) is for fueling. Is this the correct way to do it? How do I empty the tank without putting another clunk in the tank (at this point, it is just a piece of brass tubing through the cap).
Thanks for the help with all these questions.
BTW, I love this site, much faster and easier than RCO.
Dan
Old 02-16-2002, 01:40 PM
Dazzler
Put a clunk on the 3rd line, that way you can use that as your refueling, and defueling port. Secure your tank with some silicon adhesive to protect against vibration. You should not have a problem with the fuel draw as long as your tank is mounted in the standard location. Daz...
Old 02-16-2002, 02:01 PM
rumble2
Default remote fueler
don't use a remote fueler with the big saito or any high fuel flow engine. there has been many reports of fuel delivery problems when useing them. i love them on my 91 saitos and smaller but have had lean out problems on larger engines. the 3 line system works great just remember to plug{air tight} the fill line.
Old 02-16-2002, 02:22 PM
Rocketman612
My Feedback: (84)
Rocketman612's Avatar
Default Fuel tank
The 3 line tank works fine. just put a clunk on your fill line. Agree that the 2 line system with a remote fueler is a problem... Pete
Old 02-17-2002, 01:15 AM
PlaneDoc
PlaneDoc's Avatar
Default Fuel Tank
Yep, stay away from the remote fuelers. I use a fuel dot, neat and simple installation
Old 02-17-2002, 04:24 AM
TOYMAKER
Default fuel tank location
I put the tank on mine just behind the former at the wing ( on C.G.) I put the battery and throttle servo in the tank area. Balanced with no extra weight. I need to move C.G. back a little so moving the battery will be easy. I am using a Perry pump on my S.T. 2300. Flies great and and balance of the plane remains constant. Good till the last drop. Today I discovered an 18x8 wood Simitar prop worked great. I use a third line in the tank with a fuel dot. I dont use a clunk so I have to hold the plane level when defueling but works just fine.
Old 02-19-2002, 04:40 AM
wildthng
My 1st h9 cap had a saito 150 with the 3 line 2 clunk set up with a 24 oz that was siliconed in and it worked great till my elevater servo came unhooked.Never had any problems starting it but electric starters solve that problem when you can,t prime.
Old 02-19-2002, 07:36 AM
flynm
My Feedback: (24)
Thanks men, these hints are what I needed.
Dan
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
