New Great Planes Revolver
#1176
IN
RE: New Great Planes Revolver
I just got mine done and maidened this weekend. Supertiger .75 on breakin with a 12x8 prop. As you can see by the bottom picture, I have a few props to choose before I get the perfect one..... I'm thinkin the 11x10 APC will work pretty well for ballistic speed....
Who knows, a MAC pipe may be in it's future!!!!
#1177
MB, CANADA
I have a 75ax on mine and I blew off my stab tonight. Was running a 13X7 apc thin. Pulled out of a dive and the stab flew off. My control surfaces stayed put. I will post pics when I get them from the guy at the field who took them. Stab design is week. Fortunately that was all that happened, and my servo tray tore loose. All in all the rc gods were smiling on me tonight!
#1178
Holy cow! The stab blew off? Are you suprised? Well, don't be, it can......and it will. Sooooooooooo, all you guys that want to fly a sport plane as fast as it will go and then a little more, don't be suprised when the stabilizer flies off. You are on the razors edge, and once you get there, you will find a few more suprises waiting for you. Advise for you. If you are flying an all out HIGH SPEED REVOLVER, you better have a good look at the tail feathers, that is unless you want to watch the tail feathers drift down three minutes after the REVOLVER burries itself a foot in the ground. "BEEF IT UP, HAVE FUN, & GOOD LUCK! If you should think I'm dishing out a little baloney here, pay attention to Mike's thread, he has the pictures as proof every word written here. I don't mean to break anyones bubble, but the REVOLVER is not as invinceable as some of you think!
#1179
My Feedback: (10)
Too true 51er... Beefing up sure makes sense if your going to go nuts typr ballistic with this "AX 55 recommended" aeroplane. As I have said before, I'm running an OS 50 SX ringing engine on a BCM pitts muffler, and I think it has plenty of speed for anything I want to do. Cavendish's has a piped OS 50 SX on his and boy does that blow me away!
Anyway thought I'd share my latest repair with you guys. After I completed a cracker dead-stick landing only to run into the edge of a metal gate [:@] Cavendish described to me, not ever done a repair like this, how to go about my fix... easy peazy, glad its a foam wing and not built-up ( probably would have severed the wing completely! )
Some pix below to show my progress... So far I've cut out and squared up the damaged area using an old hacksaw blade and a bit of 180 grit sandpaper. Next I've found some foam ( just packing foam from a television ) and cut to fit the gap.
Masked off the repair area with some 2 inch wide masking tape to protect the good surfaces and sanded down to the wing profile with some 120 grit sand paper. Next I'll epoxy the blocks in. Good hint here from Cav... don't glue right up to the edge as the dry glue won't sand down as good as the surrounding balsa.
Going to fix on some balsa skin and a LE and cover, Show you that stage tomorrow....
Chow for now...
Paul
Chow for now...
Paul
#1180
have had a 91fx and have the 75ax on it now. no struct problems in about 7 months of flying. except of course the cheesy landing gear. i did beef up the fire wall area w/ epoxy and screws. nice repair job above.
#1181
IN
Agreed... Nice repair job.... you won't even know that it's been dinged.... silly poles....
Well, I have never been one to stick to the rules, I have a SIG Somethin Extra that was never intended to have an OS .60 in the nose and do some wicked 3D, but it's amazing what a little time and creative thinking can do in this hobby. 2 seasons and 3 gallons later, it's still rockin the boots.
The Revolver is a a great little flyer, and it was made to go fast. They say it's a sport plane, but the design says otherwise. If I rip off the elevator at speed, then shame on me.... I guess the 2 extra hinges I added per control surface, the swapped out 4-40 hardware and the monokote sealed hinge lines must not have been strong enough.....[8D]
She's a ripper so far, No flutter, and rock steady at 130mph...... WOOT!!!!
#1182
beav
you are making hard work of it, don't bother with the skin, foam should be good enough if you can get it smoothish, failing that, spend 5 bucks on a block of balsa
#1183
WI
How are you guys handling the plane sliding threw the corners? Normally I bank and use elevator to bring the tail around- but this plane just keeps slipping through. Has anyone tried coupling the airlerons and rudder by chance?
#1185
ORIGINAL: kranie
somthing is not right with your set up, this plane should pylon turn 'hard as' I've never given it full elevator when in a bank, as I feel it might rip the wings off. you need to check incidence, C of G, and be on full elevator rates.
#1186
if your model is sliding through turns when banked with ailerons / elevator, you may need to check the elevator servo as it might be a little on the weak side.
#1187
My Feedback: (10)
Corners? [X(] oh bugger, I didn't know there were any corners up there!! If there is then I must be cuttin them! lol As the guys say... there something not right there. Maybe you have another "saved" model, with pre-mixes programmed, in the TX memory that your using with your Rev??
The other day when flying with Cavendish I had a play with my Rev with very high rates on the elevators. With a high speed pull back the thing snap rolled, slowed it down and pulled and it did a nice sharp 90. In fear of getting caught out at high speed I have put my rates back down.
Finished the wing repair... not bad for my first attempt at one like this. Wish I had the right colours ( colors, to you boys State-side ) but you won't notice that at Mach 2.3 as I come passed.
CFN, Paul
CFN, Paul
#1188
My Feedback: (10)
Thanks Russ, one of many more repairs I'm sure! Might have to get one of you guys to send me a spare Revolver, cheaper than Tower charges! Just gotta watch out for those magnetic gates that reel you in like black holes! I hear there's trees like this too... plane magnets.
The 75 way better than the 91??
Paul
Paul
#1189
because of weight issues the t.h. 75felt faster than the 75ax. the 91fxw/ the jett muffler was just evil. also, just installed some h9 u-stick landing gear.bad choice.could not get the plane to stick. even on greased landings it hopped down the runway like a rabbit. back to the toni landing gear.
#1190
My Feedback: (14)
I have a 75AX on mine also and used to jump like a rabbit on landing, someone here posted about using flaperons setup on SPOILERS (both ailerons UP) and that REALLY helped, no more bouncing, i just flip up the flaperons just before landings and the revolver hugs the ground and wont let go, no bouncing
greatest tip I have seen in a while
#1191
IN
ORIGINAL: russm
right on kc. this plane was born to rock. what is in yours?
Supertiger G.75
There are a few pictures in the post I made one page ago....
#1192
My Feedback: (10)
Cool to see someone else give it a go... really settles your nerves too I think, because your not concerned about the landings as much and generally boosted my confidence all around.
Well I'm back ready for the air now and will be steering well clear of the gates! lol
Happier Landings,
Paul
Happier Landings,
Paul
#1193
FL
As I recall, There was a feature article in one of the magazines about the Revolver. Does anyone know of the issue or any article for the Revolver? Have an OS .70 4s which sounds good for this bird. Anyone? Help!
#1194
My Feedback: (10)
You probably won't find a better read than this thread on the revolver... look up HUNTERANDJEFF 's post on the Revolver, he runs/ ran an OS 70 four stroke. He's got some good video and pictures of it here somewhere.
Have a good read you'll be sure to find any answers you may be looking for and more.
Hope that's of help. ( lunchtime's over.. back to sanding my floor [:'(] )
Paul
Paul
#1195
WI
I have a 61fx in it. I am using standard hi-torgue servos through-out (Futaba 3010's) they have 72 ounces of torque. When I stand the plane 90 degrees (wings striaght up and down in a corner) the plane just keeps sliding through the turn. With my Venus, I would just give it some elevator and it would stop sliding and come out of the turn. The balance is right on and overall the plane handles very well at all speeds and attitudes. For as slipery as it is- I think it comes in for landings fairly well- better than I expected. I just have been unable to do a fly by at full speed because I can''t make turn 4 at full speed. With the 61 I am running an APC 13-6. which I realize does not allow blistering speeds- but offers good verticle and slows the plane down nicely. I am guessing the plane does about 90 mph- not nearly as quyick as some of the other I have heard about.
#1196
ORIGINAL: lippucci
#1197
ORIGINAL: beaver180
CFN, Paul
CFN, Paul
#1198
My Feedback: (10)
oh fair crack of the whip there cobba! lol I couldn't decide which edge ( leading or trailing ) to line it up with
Think if you change the engine mounts, to like on picture, you may get the engine back enough to have a tighter spinner cowl gap. It's those blimmin carbs aye!
#1199
CT
I've been following this thread for a while, and I'm thinking this may be my next plane. I've been wanting something with some speed, that will fit one of the engines that I already have. I have a Saito .82 on the shelf, and I read that someone here is getting 115 mph on the flat with this combo.
I like the idea of being able to "clock" my planes, and I found, on another thread, a link to a radar gun sold at Walmart for about $30. It's a Hot Wheels radar gun. Has anyone used one of these? And if so, how is it.
I'll try to find the link.
#1200
IN
