New Great Planes Revolver
#1201
RE: New Great Planes Revolver
ORIGINAL: freeair
thats a top repair job and thanks to the great foam wing there would have been a large re build to do. my only comment is; the Revolver sticker on the wing may be back to front, then again i am abit backward. ha.
ORIGINAL: beaver180
Corners? [X(] oh bugger, I didn't know there were any corners up there!! If there is then I must be cuttin them! lol As the guys say... there something not right there. Maybe you have another "saved" model, with pre-mixes programmed, in the TX memory that your using with your Rev??
The other day when flying with Cavendish I had a play with my Rev with very high rates on the elevators. With a high speed pull back the thing snap rolled, slowed it down and pulled and it did a nice sharp 90. In fear of getting caught out at high speed I have put my rates back down.
Finished the wing repair... not bad for my first attempt at one like this. Wish I had the right colours ( colors, to you boys State-side ) but you won't notice that at Mach 2.3 as I come passed.
CFN, Paul
CFN, Paul
i looked at the pic and thought BACKWARDS- decals also look wrong to me ha ha
#1202
CAN SOMONE PLEASE HELP ME WITH THIS
Before I throw this HYPERION eos 5i charger away for a new one, can someone please advise me if I am using this it correctly ??
I am trying to charge a 5 pack metal hydride rx 6 volt pack, no matter what input amps I programe, the charger shuts off well before the pack is charged, I have tried a charge rate of 200ma upwards, i am fairly sure that this charger does not allow you to set shut off voltage with metal hydride charging
the same as the above was happening when I tried to charge 2x (in parallel) 4 packs, she just shuts off (reads end) before getting much charge in at all.
previously I have assumed that the 2x4 pack of 2700 mah batterys(the 2 packs of 4 in parallel) would give me 5400total mah is this correct ? as I appeared to of fried them before with a 5 amps charge.
any advice on these 2 would be greatly appreciated, as I have had a couple of close ones due to being silly enough to believe that these packs were charged, I flew my 1/4 scale 30 cc zlin 50 at a rally last weekend, and the spectrum rx locked out in mid air for a short time, (due to low voltage) I have had the same thing happen with a fairly rapid g/p revolver !!!
thanks for you advice in advance, when your tx locks out in mid flight it is pretty scary !
#1206
OH
Cavandish:
The best advice I can give would be this. :
http://www.aircraft-world.com/prod_d...s5i-manual.pdf
as with anything this is the best place to start, wether we like it or not.
I'm not saying you haven't done this already but it never hurts.
#1207
ORIGINAL: thesouth1
Cavandish:
Cavandish:
THANKS but have been there, manual is fairly basic to say the least.
I managed 140 mph with my sundowner at the weekend (no nitro) will be installing the gps into the revolver this week.
#1208
i reacon you will find the Revolver will go beyond the 140 mph mark easy. i have seen a very quick Revolver going at speed and to me it looked like the 180 mph speeds, this model is owned by a previous world record holder of pylon racing.
#1210
os bgx with os pipe. amazing what a pipe does, I ran with standard silencer & it was dead, OS recon 30-40% better with pipe. I had the the same experiance with an OS 50sx in the Revolver- dead without the pipe, ugly but wow, they light an engine up if you get them the correct lenght.
"I recon you will find the Revolver will go beyond the 140 mph mark easy" BIG CALL ! mine won't, but we will see.
#1211
I am not going to read every post but so this plane was made for speed?
I got to fly on saturday with a OS55 2 stroke motor with a 12x8 prop, it was pretty fast but not as fast as my Quickie 500 with a weber 40 and tune pipe. the guys who plane it belongs to is a guy I have been test flying his planes for him, hes not a good pilot yet, he can fly but thats about it, has way to much money and always buying things he should not, this is one he should not have gotten.
anyways he couldnt land it said it landed to fast so i programed flaps for landing mod like he wanted.
what prop could he use to slow it down? maybe a 14x8? or would it sling that
#1212
it will never be as quick as a Quickie 500,the airframe is just not 'clean' enough, numbers in the 130s are about it's limit.
slow it down with more flaps or spoilers, you can give it plenty of either before aileron authority dissapears or it gets 'ugly', 60% of mid rate will not be a problem.
#1213
just put my 91fx w/ a jett muffler on mine again. was getting bored w/ the 75ax. cav, sounds like you have a nice setup. was the pipe a pain to install. i think you and i have been on this thread for a while now. keep up the good ideas. np, i think a lot of guys buy this plane not realizing it is a fast plane. no, it is not a q-500 plane, but still plenty fast.
#1214
pipe is not that much of a pain to fit, you do need a header that reaches down quite a way,
I custom made mine, but I think the large size mac's would do it. You have to re-enforce the fuse were your pipe is going to mount, as it will take the occasional hit when landing. if anyone seriously wants to fit one, I will shoot and post some pics.
#1215
CO
ORIGINAL: cavandish
Any idea where I can find an extension to fit this combo?
#1216
to make an extension, cut the engine end off the stock muff, this will extend things a bit, just remember to add it to your overall header length, make sure pipe is very secure, I have lost one already. the mount to the fuse needs to be as good as standard landing gear mount.
you can get away we a small exit hole (mine was a long oval) through that new cowl, when you need to get behind the cowl, don't remove the pipe, just slide the cowl over the engine and down the pipe
#1217
Thanks, Well they was lots of folks at the feild and I couldn't hear the engine idling for landings so I couldn't really play with it, I have like 30% flaps in it now. with I think 12 % up elevator for the corection, it tips up a little but like i said I ddint get to play with it much, we have a short feild only about 300 foot, and it runs down hill one direction so anything fast is kinda tricky to get onto the ground. I never had a issue with my q-500. but it has a little thicker wing.
The revolver is a pretty plane and it does fly nice.
ORIGINAL: cavandish
#1218
CO
ORIGINAL: cavandish
#1219
os make pre made, so try the usual places
regarding length , header length is critical (port to pipe) so you will be adding to it with an extension and may need to chop a bit off the header.
mac do an extra long header, from memory, I think this is the ideal size to fit the rev
your fuse mount needs to be as good as standard landing gear mount (it's easy, because you can use the forward servo tray bulkhead as part of this structure)
remember that your c of g with move considerably, I have 6 oz of lead on my engine mount.
#1220
ORIGINAL: Brainiax
Yes, toward the leading edge there should be a nylon dowel about an inch long. Don't go up without them in there.
BTW, anyone notice how out of scale the pilot figure is? Looks like Hulk Hogan's head on a midgets body...LOL.
I'll be looking for a little bit better fit for my model.
#1221
An average human's height is about 6x the head. If the head is 11" tall, the person will be about 66" tall.
If you look at that pilot's head and figure what height that head would be above the guy's feet...... you figure his feet would have to stick out the cowl intakes.
