 Great Planes Escapade .40 ARF >
Old 06-08-2011, 10:38 PM
  #1551
Default RE: Great Planes Escapade .40 ARF
ORIGINAL: hsukaria
ORIGINAL: DGeorge
ORIGINAL: hsukaria
Speaking of aileron control rods, mine came loose inside the wing after some time. I had to convert to dual aileron control even though I preferred the single aileron servo method.
UPS dropped mine off today. The control rod in my right wing was loose right out of the box. It pops in and out of place, and the aileron itself was poorly hinged, way off center, so much that there is a lot of pressure between the end of the aileron and the wing. Should I call Tower or GP? I think I read somewhere in this thread that somebody was sent a wing half without having to even ship back the original defect.
Whomever you call, do it quick...we are running out of flying season. That's a bummer about the wing though. I can't believe it passed the tight Great Planes QC .
Yup, bummer indeed, especially when I opened the book and saw that the wing was the first step in puttingthe plane together.The first thing I asked myself was "man how did this piece make it past quality control?" Everything else seems to be solid and put together well. All the hinges are well glued, as well as the torque rod in the elevator. I had to iron out quite a few wrinkles and trouble spots in the covering, but that is to be expected.
I had originally planned toget it togetherfor a maiden flight this weekend, soIhope I can get this wing replaced without hassle so I can get her off the ground as soon as possible. In the mean time I might as well go forth with the fuse reinforcements and get the tail end all finished up and glued in with the Sullivan tail-wheel assembly, assuming everything lines up and falls into place.
Old 06-08-2011, 10:45 PM
  #1552
D
ORIGINAL: DGeorge
ORIGINAL: hsukaria
ORIGINAL: DGeorge
ORIGINAL: hsukaria
Yup, bummer indeed, especially when I opened the book and saw that the wing was the first step in putting the plane together. The first thing I asked myself was ''man how did this piece make it past quality control?'' Everything else seems to be solid and put together well. All the hinges are well glued, as well as the torque rod in the elevator. I had to iron out quite a few wrinkles and trouble spots in the covering, but that is to be expected.
I had originally planned to get it together for a maiden flight this weekend, so I hope I can get this wing replaced without hassle so I can get her off the ground as soon as possible. In the mean time I might as well go forth with the fuse reinforcements and get the tail end all finished up and glued in with the Sullivan tail-wheel assembly, assuming everything lines up and falls into place.
DGeorge............what do you mean by fuse re-enforcements???? I didn't notice any weak areas on my first Escapade and looked my new one over really well and don't see any problem spots. I had 8 months of flights on my first one before I planted it and had no troubles whatsoever. Tail end just bolts on so you don't need glue.
cheers,
Andy
Old 06-08-2011, 11:09 PM
  #1553
I remember seeing in this thread someone that put a couple triangle gussets just rear of where the gear bolts come through the bottom. I thought it seemed like a good idea and is easy enough so I figure, why not? Several people here had issues with the tail coming loose and constantly having to re-tighten it so I think I'll just glue the whole thing down for piece of mind. I might end up with several ounces of added weight from extra epoxy and such, but better safe than sorry.
Old 06-09-2011, 06:14 AM
  #1554
DGeorge, you can glue the tail if you want to. But I just used Locktite and it hasn't come loose in 2 years. Also, not having it glued came in handy when I crashed and destroyed the fuselage 2 years ago. I just unbolted the tail and re-used it and the wings on a new fuse. JMO.
Old 06-09-2011, 06:53 AM
  #1555
I just bolted on the tail assembly on the Escapade and have had no problems in the three seasons I have been flying it.
Bruce
Old 06-09-2011, 07:49 AM
  #1556
markhamregular's Avatar
<p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font face="Calibri" size="3">My Escapade was landing too fast so I took off all the weight that I had added to the nose (9 ounces). Now the plane is extremely tail heavy as per the CG machine (2.5” from leading edge) but at the field, she is flying like a bird and landing in much slower speed. So that CG that the Chinese or Vietnamese builder was WRONG.</font></p><p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font face="Calibri" size="3">I also replaced the flimsy tail wheel, so I don’t have to fix a wheel after each landing.</font></p><p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font face="Calibri" size="3">Now, my only question is the roll. My rolls are slow while the Escapade on the flight simulator allows me to do very fast rolls. I have a plain vanilla FM radio so I may have to re-adjust the rods on the servos to give the ailerons more throw. I am a beginner (6 months flying, 5 gallons of fuel under my belt) what is the best throw I should have on the ailerons without making the plane too responsive. <span style="mso-spacerun: yes"> </span>Thanks.</font></p>
Old 06-09-2011, 09:17 AM
  #1557
Just an update about my defected wing. After describing the issue the rep tried to poke around the issue as if there wasn't one, as if I didn't have a perfectly fine left wing to compare this garbage to. I was finally told to email pictures and a description of the problem and that the process would start from there (is that not why I called? to speed up the process by bypassing a potential e-mail fiasco?). It isn't worth the time or effort to be givena possible multi-week run around, just to get a significant piece of the plane replaced which is clearly not built to spec. Very dissappointed, as this is my first and last purchaseof a GP aircraft.
Does anyone want to buy a 1-day old unboxed Escapade 40 in need of a replacement wing?
Old 06-09-2011, 09:20 AM
  #1558
DGeorge,
Sorry about your problems with Tower. I have been buying from them since 1995 and have never had a problem getting GREAT customer service. You might try calling again and you might get a different rep.........or just ask for a supervisor.
Andy
Old 06-09-2011, 09:25 AM
  #1559
ORIGINAL: oldtyme
DGeorge,
Andy
I called Great Planes, not Tower.Maybe it's worth a call to them before I give in.
Old 06-09-2011, 10:04 AM
  #1560
DGeorge........did you call the 217-398-8970 Ext 5 number?
I had one small piece missing in my ARF and a phone call and it's on it's way.....no questions.....they can see where you bought it and when.j
Cheers,
Andy
Old 06-09-2011, 10:53 AM
  #1561
ORIGINAL: oldtyme
Cheers,
Andy
I went ahead and sent an email with a photo description of the aileron issue (the control rod issue really can't be captured with a photo), and then called using Ext. 5.The gentleman I spoke to actually saw my e-mail and confirmed that he recognized the issue. He said he would forward itto the "aircraft guy" who is probably the original fellow I spoke to in the first place.
I hate to flame, but I'd expect that if I'm sold a C-rated product by a large reputible company that they would compensate with A-rated service (which many have claimed to receive). It has definately not been a "no questions asked" situation in my specific case, but I haven't been denied a replacement as of yet, so my hopes are up. My issue probably isn't one they hear about a dozen times everyday so I can understand their need to probe deeper.
Old 06-12-2011, 11:33 AM
  #1562
Well after a long inverted flat spin my Escapade departed for a better place. RIP....................
Maybe I'll buid another one............
Old 06-13-2011, 08:12 AM
  #1563
While I've been waiting for my replacement wing I went ahead and finished up everything else except for battery placement. There aren't many options, but hopefully I can balance the bird properly with the battery so I don't have to add additional weight. It seems most have found that initially balancing the plane per the books recommendation (2.5" from leading edge) has provided less than desirable flight characteristics, and when removing all theadded weight, though more tail-heavy,they found the plane more enjoyable to fly, and landings to be slower.
Is thispurely a CG issue, oran exampleofthe plane being overweighted after all thelead added to get the CG at 2.5"?A combination of both, maybe?
Old 06-13-2011, 08:21 AM
  #1564
After I flew my Escapade for the first couple of times (it balanced with no weight whatsoever) I found that I was having to hold too much up elevator to make landings. I added about 3/4oz of weight to the tail and it was perfect. I think with this plane you need it a tad (not much) tail heavy to be most enjoyable.
Old 06-13-2011, 09:00 AM
  #1565
So, very slightly tail heavy at 2.5 inches from the leading edge? I decided that I'm going to maiden the plane with an OS .52S that I already had. I probablywon't have the power to spare for additional lead, soI'm hoping mine balances without weight too.
Wouldyouhappen to know the overall weight without fuel of yours?
ORIGINAL: oldtyme
Old 06-13-2011, 10:58 AM
  #1566
ORIGINAL: DGeorge
So, very slightly tail heavy at 2.5 inches from the leading edge? I decided that I'm going to maiden the plane with an OS .52S that I already had. I probably won't have the power to spare for additional lead, so I'm hoping mine balances without weight too.
Would you happen to know the overall weight without fuel of yours?
ORIGINAL: oldtyme
Sorry no............my first one is just a memory......(builder's mistake as mentioned earlier in this thread)..........and I haven't quite gotten my current one finished but when I have it done I'll let you know. I have almost all the same gear in it so should be close to the first.
Old 06-13-2011, 11:00 AM
  #1567
Mine following the CG of 2.5" of the manual is not a tad tail heavy, it is VERY tail heavy.
But like I said earlier in the thread, it flies much better and lands nicer since I took off the nose weights.
Old 06-14-2011, 01:50 AM
  #1568
Harry, Your Escapade is not tail heavy, its still nose heavy. You've just accepted that the CG is actually further back than the manual wants it. the Manual is wrong.
Before I trashed my Escapade I had the C back at 3inches from the LE and its was just slightly still nose heavy.
Old 06-14-2011, 02:37 AM
  #1569
Do the builders of those planes visit sites like this?
Do they listen to their customers, those who actually fly those planes?
I would think the first batch of planes, but then they could change one number in their manual and VOILA!
In oher industries this is part of something called marketing.
 know it's a hundred-dollar plane, but it does not cost much to correct a simple mistake.
Old 06-14-2011, 02:51 AM
  #1570
Hey guys, I have been flying the Escapade 40 for three years and have the CG at the instruction's recommended place. I do not find the plane nose heavy at that location and it flies great as is. I did not need to add extra weight to get it to balance there. All I did was place the battery over the fuel tank, that is with a Magnum .46 RLS in the nose.
Bruce
Old 06-14-2011, 03:57 AM
  #1571
I also placed my battery over the fuel tank and I have an OS46 placed at the recommended location.
I think that not all Escapades are made at the same place under the same QC rules.
I think that some are built by chinese, others by Vietnamese.
Mine was definetly landing way too fast and the nose heavy was the problem
Old 06-14-2011, 05:00 AM
  #1572
mschulz531's Avatar
Build from a kit and you won't have these QC problems to worry about.
Old 06-14-2011, 05:09 AM
  #1573
ORIGINAL: mschulz531
Yep, then you only have yourself to blame when the plane fails.
Old 06-14-2011, 05:21 AM
  #1574
<p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font face="Calibri" size="3">My first plane was a kit. It took me 80 hours to build it, and the job was not that good.</font></p><p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font face="Calibri" size="3">That’s the problem with kits. First, if you are not handy, you are not guaranteed to do a good job, then spending so much time building it makes you nervous flying it. The time put in it is more important than any money spent on an ARF. And then, I am not retired.</font></p><p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font face="Calibri" size="3">As much as I enjoy building, flying is more enjoyable to me. </font></p><p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font size="3"><font face="Calibri">I will continue to buy ARF built in Vietnam hoping mine is not that bad, but ranting when it’s bad </font><span style="FONT-FAMILY: Wingdings; mso-ascii-font-family: Calibri; mso-ascii-theme-font: minor-latin; mso-hansi-font-family: Calibri; mso-hansi-theme-font: minor-latin; mso-char-type: symbol; mso-symbol-font-family: Wingdings"><span style="mso-char-type: symbol; mso-symbol-font-family: Wingdings">J</span></span></font></p>
Old 06-14-2011, 05:28 AM
  #1575
mschulz531's Avatar
I'm not retired either, and I still have young kids...but I find time to build (I have ARFs as well) during inclement weather or late at night to unwind from the day. You are correct when you say that it takes a certain amount of resolve to maiden a plane that you have taken so much time to build. I just wonder sometimes if the amount of time spent "putting together" and "strengthening/modifying" an ARF ends up making the time difference between an ARF and a kit less than most people think.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
