VQ Dego Red
#53
GA
RE: VQ Dego Red
I'm at the point of attaching the cowl. Haven't had much luck with cowls in the past. Did you guys attach the cowl at about the trailing edge right into the side of the fuse., or did you move the screws forward about 2 inches in order to screw it into the side of the firewall block. Any pictures would be great. Thanks again.
chopper
chopper
#54
GA
RE: VQ Dego Red
Well the day finally arrived. Maiden the Dago today. All in all not to bad. Had some CG issues even with the CG set at the recommended setting. On the stand it was a little nose heavy but for some reason it flew tail heavy. Not sure why but it did. Took some wight off the tail and it flew much better. The gear colasped on landing because the wire somehow got bent. It was not a hard landing either. Not sure about than one either. The two flights definitily went better the the Kaos flight. No parts left Oh well the Dago lives to fly anouther day.
chopper
chopper
