Seagull Edge 540 78"
#76
1 Post
Hi where it’s your C&G onThe seagull edge540 blue ? I build one as well and it’s looks like I have ad a lot of weight on the front more then 500g . I have high tongage mac Gregor servos on it each one 69g *5 all back to C&G point . Or it’s normal I have add some weight on ??
thanks
thanks
Having 3 servos in the tail is just too much unless you have a 50cc petrol engine and big batteries up front.
Flies nicely though.
Anton9040 (03-22-2020)
#77
I have more than 14oz to put in but if on tube center it’s will be 6-8oz
and engine I have use is DLE35 RA 2 batt. 2 cell live 3000 and one ignition 2000 . And tail it’s heavy I think because of the high weight of servos . But I can’t move them . One for throttle is in the front and 2 batt. for servos on side of f.tank . In the end we have today check C&G ang put about 300 grams to get C&G on the center of tube . What’s it’s means I have with this 300 g weight my C&G is 3cm / 1inch back original what they are recomend in manual.
im apologize for my English not so good
thanks
thanks
#78
1 Post
thanks
thanks
You say you "can't move" the rear servo's. What you actually mean is that to move the servo's you would have to modify the kit.
The first thing I would do is get rid of the pilot figure. This is worth about 100g in the nose.
Put the engine servo, ignition system and battery in the engine bay.
Try to get the receiver battery in the engine bay.
Use an alloy spinner.
Instead of having nose weight as useless lead, try building up the inside of the nose area with flexible plywood (1mm). I found the original wood was so flimsy I would crack it just by picking up the model.
If you still need nose weight, move the rudder servo forward and connect to the rudder using push-pull cables. 100g moved from the tail is worth 400g added to the nose.
There used to be heavy weight spinner inserts that put a weight very far forward.
Any weight you add should be as far forward as you can manage. If it is attached to the engine or engine bearers, it damps vibration in the fuselage.
