Showtime 50
Hello i tried to find reviews of this plane but i didnt find as i have found for the reactor by GP...
I have Reactor but i have problems withthe monokote and i dont like it, i am thinking of buying a shotime 50 and put on the 91 saito from the reactor what to you have to say.... can i put on the engine or i have to change something?!
Or to go str8 to the Showtime 90 with a 125 saito... !?
i know that this is the best but everything in my reactor is new and i dont want to sell them all i want ot kepp the saito 90.. the showtime 50 isnt a good plane? isnt better from Reactor?
My Feedback: (13)
NJ
I have a showtime 50 with a Saito 91. For the engine install you will either have to shave down the inside of the mounts(advise against)...or redrill new mouting holes which is what I did. I was a little leary at first as this was the first time I had done something like this, but I am pleased that I did. It really wasn't that difficult. Just make sure you have the centerline lined up correctly. Its definitely a good power combination. Use a 14x7 apc prop.
The Magnum 91 4-stroke is awesome on this bird, the only problem is, the 91 is thristy and the tank is small. What size tank should I go with for longer flights?
