Reload this Page >
Larger Revolver
Larger Revolver
Old 12-28-2010, 03:34 PM
  #2501
microdon2
My Feedback: (47)
Default RE: Larger Revolver
It snowed about 18" here in NY on Sunday, and the gusting wind is finally calming down, so I'll be taking the Rev 70 (with the YS 140) out to the field tomorrow morning on skis. Just put them on the plane and I'm psyched! I'm guessing by tomorrow the snow will have settled down some and should be flyable. Weather projection for 9am is winds at 11mph WNW and 28deg F, so not bad. Will report back with the results.
Old 12-28-2010, 03:52 PM
  #2502
SpinnerRow
SpinnerRow's Avatar
ORIGINAL: microdon2
LOL!!! Down here in Texas, we would freeze to the field in conditions like that. We call 45 degrees, sunshine and 10mph wind "not bad" here. Or in the summer - 95 degrees and no wind - "not bad". But 28 and any wind AT ALL - no thanks! I don't think I have enough clothes to fly in weather like that.
Old 12-28-2010, 04:05 PM
  #2503
microdon2
My Feedback: (47)
Ah, with my long underwear, a turtle-hood, a turle-neck shirt, gloves (for fueling) and a Raydiowarm, I won't feel the cold at all. LOVE it, in fact. The snow makes for a really nice, smooth runway.
Old 12-28-2010, 06:22 PM
  #2504
Slow and Steady
28 degrees and 18" of snow?? Today it was a cold 58 degrees, but tomorrow it is supposed to warm up to 72 with a lite breeze. Thank goodness for sunny South Florida. Now if we could only do something about Hurricanes, Iquanas and Pythons. Not to mention West Nile Monitors.
Old 12-28-2010, 06:39 PM
  #2505
afjetmech
14 inches of snow here on Sunday. 65 degrees on tap for Sunday. Crazy weather to say the least. Can't wait to get my new servos in and fly the snot out of the Rev 70 this weekend. (well at least make its nose run a little)
Old 12-28-2010, 06:41 PM
  #2506
microdon2
My Feedback: (47)
Didn't you forget the crocodiles and alligators? That said, I would rather have the 72 deg and calm, but this is NY!
Old 12-28-2010, 08:21 PM
  #2507
Slow and Steady
Alligators, Crocks - they usually wont bother you if your carefull, but a 20' long Rock Python, with a body the size of a telephone pole. They are man eaters in their native Africa. I'm sure they make for a nice pet! Fortunately they don't seam to hang out at our flying field yet. I thought this was a Revolver 70 thread?
Old 12-30-2010, 08:23 PM
  #2508
microdon2
My Feedback: (47)
Excellent flying this morning on the snow with the Rev 70 and the YS 140. The skis worked perfectly. Weather was very mild - 30 F and 3mph WNW. Landings were a bit quick, though, so I swapped out the 15x12 prop for a 16x7, and that made all the difference. Also felt like I had lots more control at low speed - allowed me to do some nice very-low inverted passes and better knife-edges. Going out tomorrow morning with my other Rev 70, with the DLE 20. Hopefully I'll get the carb dialed in this time. Going to move the skis over now.
Took pics in the field this morning with the Blackberry (attached) but they came out dark. Looks like night, but it was actually VERY bright out at 10am. Must have been TOO bright for the camera, with the sun bouncing off the snow. Will have to see if I can change the F-stop on a Blackberry...
ID:	1540135   Click image for larger version
Old 12-31-2010, 06:22 AM
  #2509
wjcalhoun
Love the skis, Mike
How does the YS start in cold weather; did you have to use lighter fluid to get it running?
How much wt difference is there between your two R70s with the YS and the DLE20?
Old 12-31-2010, 12:17 PM
  #2510
microdon2
My Feedback: (47)
wjc - thanks about the skis. The Rev 70 with the YS 140 is definitely heavier (though I don't have an accurate scale), by the engine alone. And, because the YS lies on it's side, part of that weight is off-center, which means I had to add weight to the opposite wing for balance. All of that adds weight and "moment" (think that's the right term) to the plane - as a result it does rotate slower than the Rev 70 with the DLE. The YS did take some work to get started yesterday - I probably should have primed it more. But once that engine get's going it's a beautiful beast - runs smooth as glass while it gulps my Nitro. The DLE is much easier to start, though doesn't run quite as smooth. Flew the Rev70\DLE on the snow this morning on skis (though the snow was getting sticky at the end there, started to warm up here). From what I've read the DLE will run better as it breaks-in.
Old 12-31-2010, 03:06 PM
  #2511
wjcalhoun
Best wishes to all for a happy, prosperous, and blessed new year for 2011!
Bill
Old 12-31-2010, 05:02 PM
  #2512
SpinnerRow
SpinnerRow's Avatar
Finished my Rev 70 today. Came out to 8.75lbs with a Saito 100 in the nose. I've had this engine in WM P-51 for a year or so and love it. I'll run a 14x8 or a 13x10. Tower TS-160 on the elevator (a rebadged Hitch 5625MG), a Hitec HS-5625MG on the rudder, a pair of Tower TS-140s on the ailerons (MG 82 in/oz) and I've got a HS-225MG on the throttle. Hydrimax 6v 2000 mah battery.
ID:	1540547   Click image for larger version
ID:	1540548   Click image for larger version
Old 12-31-2010, 05:12 PM
  #2513
Slats!
I had the same set up (engine). You will find the motor and plane like the 14 much better. The engine seemed smoother and the speed was the same but the plane was more stable with the 14 as well, defiantly use the 14 on the maiden until you get used to the speed this thing has on landings. Good luck.
ORIGINAL: SpinnerRow
Old 12-31-2010, 06:25 PM
  #2514
Kostas1
Kostas1's Avatar
Is it fast with the FA-100 ?
Old 12-31-2010, 09:36 PM
  #2515
Slow and Steady
Likewise WC! Best wishes to all in the coming year!!
Old 01-01-2011, 05:30 AM
  #2516
SpinnerRow
SpinnerRow's Avatar
ORIGINAL: Kostas1
Don't know yet. I'll let you know when I fly it.
Old 01-01-2011, 06:13 AM
  #2517
Kostas1
Kostas1's Avatar
Old 01-01-2011, 08:04 AM
  #2518
wjcalhoun
Spinner Row
How did you determine that the T-160 was a rebadged HS5625?
Old 01-01-2011, 12:16 PM
  #2519
SpinnerRow
SpinnerRow's Avatar
ORIGINAL: wjcalhoun
Spinner Row
The specs and the case are identical.
Old 01-02-2011, 05:42 AM
  #2520
afjetmech
Happy New Year? Not. This is what happens when your DLE20 stalls and forces a landing far off the end of the runway in the rough. A bad bounce killed the airspeed and she nosed in from about 8ft. Only the 4th flight. Also had a pinion slip on my scale 90sized Agusta. 15 pounds of heli doesn't auto to well with an already low head speed. Pretty crappy newyears day flying for me. Oh well, at least Ihave something to keep me busy.
ID:	1541096   Click image for larger version
ID:	1541097   Click image for larger version
ID:	1541098   Click image for larger version
ID:	1541099   Click image for larger version
Old 01-02-2011, 08:14 AM
  #2521
microdon2
My Feedback: (47)
afjetmech - Sorry to hear about your crashes. For the DLE20 stall, mine (on my Rev 70) has been stalling off and on (fortunately I've had some altitude each time, enabling relatively easy dead-stick landings), and it looks like I was running it too lean. (I have only about one gallon through it so far). But if I close the high-speed needle by only about 1/8th the engine will stall while doing a knife-edge. My impression (and from reading from others) is that you need to run this engine rich until fully broken-in. Thpugh that produces gurgling during mid to full throttle running. Could yours have been running it a bit lean? Anyone else have any info \ experience with this? Thanks.
Old 01-02-2011, 08:21 AM
  #2522
afjetmech
Actually Ihad it a little rich, then turned the H needle in about 1/8 turn. Close to "factory" setting. It was stalling on throttle up so Iwas told to richen the low end a little. Seemed to help, but then it stalled the last time when Ithrottled down. Ishould have kept the idle up a little higher. Advise to anyone using this engine. Remove the idle stop screw completely. It punches a nice hole in the cowl if your engine breaks loose. Ihad it backed out, but not removed.
Old 01-02-2011, 08:54 AM
  #2523
Slats!
I am no expert on the DLE 20 as I do not own one but have the 55 and know a ton of people running the 55. Unless you see whats going on its hard to say why things dead stick. Allot of time it is peoples tuning but I have seen people with issues outside of that such as the carb or ignition. A couple of things:
-GET RID OF THE CHEAP PLUG that comes with this thing. I can't tell you the amount of times I have read and seen people having issues with the crappy stock plug.
-Burble, get used to it. Its gas and not broken in if you lean the engine while its breaking in to get rid of the burble you are going to screw it up and you will risk dead sticking. It gets better as it breaks in.
-Tuning is pretty straight forward. First find the high end, find the max RPM by leaning (with a tach) and then richen it a little, the engine will take time breaking in.
-Once this is done find the low end, lean it until it stalls when throttling up and then richen it a little. You will have to keep leaning the low end as it breaks in.
The carbs are sensitive 1/8th is a ton. At first I wondered why I went gas LOL. One click on the low and it would throw it out of wack. As an FYI this thing will also stall if you are to rich as well on the low end. At the end I love it.
If a lot of people are having problems with this engine on the revolver it could be the cowl as well. You can run a carb equalizer (film canister) that will help it.
Of course it can always be your set up.
Old 01-02-2011, 09:13 AM
  #2524
microdon2
My Feedback: (47)
Slats - thanks for the good and detailed feedback.
Old 01-02-2011, 09:27 AM
  #2525
Slats!
Not a problem, Loved the pictures of the revolver on skis I may give it a try.
Everyone needs to just pitch the stock plug its such a cheap fix that has been known to cause a ton of problems.
Below is a pretty good thread on gas set up (Al Lewis on flying giants, gas for newbees) he shows the film canister and some other things. I hated gas at the start I didn't have any dead sticks but saw enough that it made me nervous.
http://www.flyinggiants.com/forums/s...ad.php?t=53943
What a joke you cannot put flying g in LOL.
