 Rossi engine help >
Rossi engine help
Rossi engine help
Old 07-09-2010 | 09:03 PM
Default Rossi engine help
Does anyone have or know where I can get a carb for a rossi 40 engine. My throttle screw in the middle of the throttle arm will not turn. It is froze tight. I have the barrle out and no luck. Thanks for any help.
Flyer1
Old 07-09-2010 | 09:05 PM
Default RE: Rossi engine help
Flyer1
Read more: http://www.rcuniverse.com/forum/m_98...#ixzz0tF0MBCKL
Old 07-15-2010 | 10:58 AM
You can do one of two things. You can get a replacement Rossi (OEM) Carb from AXE Rossi, or you can purchase a Perry Carb for the Rossi engine that you have. I have heard that the Rossi carbs are a bear to adjust, and I have heard nothing but good things about the Perry carbs.. <div>
</div><div>I purchased 2 Perry carbs for  my Rossi engines. i have yet to run them, but they look extremely simple to adjust. </div><div>
</div><div>You can get the Perry carbs directly from Perry, or you can get them from AXE Rossi.  I purchased my Perry carbs from Axe Rossi, Via fleabay, because I got the carbs a bit cheaper than if I had bought them directly from Axe Rossi.</div><div>
</div><div>AXE Rossi web site  www.rossienginesusa.com</div><div>Perry web site    http://perrypumps.com/</div><div>
</div><div>Good luck, Craig. </div>
