I need control throws for a DP Ultimate
Hi all I bought a used DP Ultimate could someone be kind and give me the low and hight rates for this bird. Thanks!
umm..which size ultimate is it? :)
Oh that's right I keep forgetting they make 2 sizes now. It's the 120 sized Ultimate.
Sorry Cap....I can't help you then. I have it's little brother.
I can't believe nobody has a Dave Patrick Ultimate 120 sized that can give me control throws from their manual. Oh well I will find the info somewhere else. Thanks anyways!
Dude,
I have got one, but the manual is at home right now, and I am at work. If I remember I will get them for you and post tomorrow. Also, what engine are you using? I have a Saito 1.80 bolted on, and am in the middle of assembly right now. I have heard it will balance on the nose-heavy side with the Saito, has anyone else experienced this? |
Saw your thread the other day and thought for sure you would have had them by now..here they are.
High rate Values: up Down Aileron 3/4" 3/4" Elevator 2-1/2" 2-1/2" Rudder 3" 3" Low Rate Values: up Down Aileron 1/2" 1/2" Elevator 1-1/2" 1-1/2" Rudder 2" 2" High rate expo values---60% on everything Low Rate expo values - 16% on everything |
Thanks RCJones I'm going to fly her tomorrow.
ShakeyJake, mine is fitted with a Moki 1.80 and yes it's a tad nose heavy. |
I have got the Ready-to-cover version. I had heard that it typically comes out a little nose heavy, so I mounted dual elevator servos in the tail.
I was also able to easily double bevel the horizontal and vertical stabs. Other than that, pretty much stock. I should be covering by the end of this weekend! Jake |
1 Attachment(s)
I just did the arc and it was tail heavy with a Saito 150. I put 4oz in the cowl and am slowly taking them out. It may not be really that tail heavy but it seemed that way to me. Better safe than sorry I figured. Hate to go up with a tailheavy bird.
| All times are GMT -8. The time now is 04:39 AM. |
