Cloud Dancer 40 CG??
I've just completed my first ARF, Cloud Dancer 40 - with a Sunpass 70!
My question is - directions state CG = Center of Wing Main Spar. Where exactly is this?? Thanks, The Rookie |
Many wings have their leading edges sheeted back to the main spar. Then it's open rib bays until the trailing edge sheeting. If your model is like this then use the rear edge of the leading edge sheeting as your CG point. If not -- measure the chord of the wing, the distance from the leading edge to the trailing edge, to determine the mean aerodynamic chord, MAC of the wing. Then set your CG 25% of that distance back from the leading edge. This will put your CG at 25% MAC and thats a good starting point for a constant chord wing. From there you can fine tune the CG with flight testing to get it where it best suits your flying style.
I built the cloud dancer .60 ARF and per the instructions, it said to lift the plane on the wing tips at the main spar. There should be a diagram in your instruction book giving a distance in inches for the CG. Just make sure you measure from the tip s of the wing and not towards the fuse since the wings taper.
| All times are GMT -8. The time now is 12:41 PM. |
