GP Eagle 580 4 st muff inside cowl???
I have a G P Eagle 580arf 53" and I plan on putting an Os .81 fs in it.
My plan is to route the exhaust back under the cowl and out the bottom. If I use the stock muffler inside the cowl will it get too hot? Thanks Jimmy |
RE: GP Eagle 580 4 st muff inside cowl???
Just make sure you have plenty of airflow. The rule of thumb is an air exit that is 3x bigger than the inlet I believe or something like that.
ORIGINAL: ChuckW Just make sure you have plenty of airflow. The rule of thumb is an air exit that is 3x bigger than the inlet I believe or something like that. Cool, thanks! Jimmy |
| All times are GMT -8. The time now is 03:13 AM. |
