RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Kangke cap 232 120size excelence (https://www.rcuniverse.com/forum/arf-rtf-75/1021896-kangke-cap-232-120size-excelence.html)
acropad 08-04-2003 10:04 AM
hi guys just bought my new 1/4 scale cap 232 made by kangke (supercraft) ARTF.
i have not started to build it yet but from wen i oppened the box quality ignited my eyes. the quality of the balsa joints are really precise and the covering quality which i was told was ultra cote (profilm) is put on better than any other artf i have had and i have had a fair few (fantastic quality).
so now u guys are probly wondering how heavy this plane will come out now i can tell you its quite alot lighter airframe etc than my 1/4 extra and that came in at 13lbs. i am exspectin this to come out 12lbs with a mackay aw30cc gas engine.
people who want a slow flying plane like i did when i was researching this plane i dont think this is going to be a problem this plane has 1200sq of wing area which in theory means it will fly very slow indeed.
however i have not yet put this plane togeather but ill keep use updated on this new bird if use like. an ill put some pics on when its finished and give a flight report hows that.
oh yes an the new hardware Kangke are starting to put in is really really good. blue metal anodised horns (nice) and all push rods with metal chrome clevisis. this is definetley the best hardware i have ever seen in an artf infact i dont think i could do much better my self by goin out an buyin new hardware it really is descent stuff.
ps: i have just been told that the 1200sq.in is not all on the wing they measure the botton side of the fuselage too.
but i think it will still fly slow enough.
pps. wow the sisze of that cown it seriously looks like its of a 1/3 cap.
ok
acropad 08-17-2003 09:32 PM
1 Attachment(s)
not built yet but am iching to see what it looks like wen its up so i decided to just put it togeather temperelery.
heres some snaps hope u like em!!!!
acropad 08-17-2003 09:33 PM
1 Attachment(s)
another
acropad 08-17-2003 09:36 PM
1 Attachment(s)
err another.
i am 5'8" just look how big this fuselarge is wow thats big for 1/4 scale
acropad 08-17-2003 09:38 PM
1 Attachment(s)
nice 74" wing span
acropad 08-17-2003 09:42 PM
1 Attachment(s)
one more...lol
RickC2009 08-18-2003 07:30 PM
looks Great!
Where do the elev and rudd servos mount?
Can they be put in the tail?
Rick
acropad 08-18-2003 10:13 PM
there are servo slots for the elevator servos in the tail but i dont think the rudder.
pull pull for rudder or snake etc with servo in CG lines
OUTCAST 08-18-2003 10:19 PM
Be sure to seal all the hinge lines, it make a noticable improvement in stability.
acropad 08-19-2003 12:29 AM
whats do u mean seal the himge ling.
what with an y what does it do?
thanks
an have u got one of tthese planes?
thanks
Flyfalcons 08-19-2003 02:17 AM
These things fly great!!! You'll love it! 3D is great for a 25% plane; Harriers are rock solid. The one I flew had an ST 2500 in it, and it powered it well. A Moki 1.8 would probably make it rock. Those red wingtips are very visible in the sky.
OUTCAST 08-19-2003 10:13 AM
Acropad, you seal a hinge line by installing covering between the control surface and the fixed surface. I use clear Ultracoat so I don't have to worry about matching the colors on the plane. I cut the Ultracoat into a strip about 12mm wide, then fold it length wise. While holding the control surface to its maximum deflection iron it in the hinge line. This prevents any air from leaking through the hinge gap and greatly improves response, reduces the chance of flutter, and keeps the control working an lower airspeed. I do not own the Kangke Cap 120, but there are two in my club and I have lots of stick time with them. I do own the Kangke Laser 2000 and the Texas Hurricane.
acropad 08-19-2003 10:21 AM
thanks guys......
so OUTCAST u say u fly the plane abit what do u think of it?
a what is it like on the landings?
does it snap? tip?an how fast etc does it stall?
thanks
OUTCAST 08-19-2003 07:33 PM
The two that I have flown are very nice with no bad habbits. They harrier well, do nice blenders, will fly much slower than you would think they should and are very easy to land. I have not noticed and tendency to tip stall but it will snap like crazy if you ask it to. I think they are the most stable Cap's I have flown, and I intend to buy one for myself.
SunShyne 08-19-2003 07:50 PM
anyone have any exp with it with a 1.60FX?
geoff_nwt 09-26-2003 05:30 PM
RE: Kangke cap 232 120size excelence
acropad who did u say is building it ? see ye latter dad
acropad 09-27-2003 03:00 PM
ME!
cant you read!
Hopsterguy 09-27-2003 06:52 PM
Dad... ya gonna let him get away w/ that snap? :D
If the cap snaps half as well as he does, it will be wonderful.
-Steve
acropad 09-27-2003 08:53 PM
IN that case the cap wont snap lol.. ;)
geoff_nwt 09-29-2003 08:14 PM
Pad if you build it it will snap all right in half
I have read the instructions and it did not mention the use of a sledge hammer and nails so thats u knacked
Anyway I like you little dancer looks like someone has got your frequency peg again
OUTCAST 09-29-2003 08:51 PM
Man, you guys are brutal! :)
paully 01-04-2004 02:29 PM
hi there to all
im just writing tolet you know that im also building a kangke cap 232 120 size and i have lobbed an mds218 on the business end!!! should 3d alright eh?????
acropad 01-06-2004 08:47 AM
218 should be good.. ommm mds id say maybe same power as moki 180 or OS160 but either of them are more than enough so no problems there.
famousdave 01-12-2004 12:17 PM
Check out my comments and detailed pictures on this ARF near the bottom of the thread linked below. I LOVE this plane. It is the best flying scale model I have owned and everyone at my field loves it! Honestly, this is the best flying CAPs I have flown and with the exception of the 35% Carden CAP I had it is quite possibly the best flying plane period.
I have 40+ flights on it so far and it still looks like it came out of the box.
See my notes about the recommended mods though... the gear and wheels suck! But for the most part A+++
http://www.rcuniverse.com/forum/m_44...tm.htm#1398546
DP
TooLy 01-12-2004 08:22 PM
Did you saw Joe Hunt review on it?
http://www.rcuniverse.com/product_gu...67&kit_id=1512
