RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   tail wheel for US 60 needed (https://www.rcuniverse.com/forum/arf-rtf-75/1030234-tail-wheel-us-60-needed.html)
flysforfun 08-06-2003 05:11 PM
I am in the process of building my 2nd H9 Ultra Stick 60. I m not really sure I like the design and hardware for the tail-wheel and assembly that comes with the ARF. I would like something that is a little more rugged, and would like to use a larger wheel. Any suggestions would be appreciated.
ptgarcia 08-06-2003 05:29 PM
Sullivan tail wheel
I used the sullivan tail wheel bracket and the stock wheel. Just match the bracket size to the weight of the plane.
NOVAflier 08-06-2003 08:11 PM
I am doing the same thing, with the sullivan. Can you send some pics of the spring to rudder configuration? Not sure the best way to go about it.
ptgarcia 08-06-2003 08:30 PM
NOVAflier,
I wish I could but I buried my US 60 a couple of months ago :eek: I was so bummed, its a ton of fun to fly.
Anyway, what I did was peel away the covering and CA'd an 1/8" or so thick lite ply spacer where the bracket mounts to get the clearance needed for the spring and help strengthen the mounting point. Then I simply screwed it to the fuselage with wood screws, no blind nuts or anything, then bent the spring up and pushed it into the bottom of the rudder. I put a drop of thin CA at that point and thats it. Easy and held up perfectly. I do recommend the stiffer spring if you fly off anything other than pavement. Good luck!
WesleyK 08-07-2003 02:42 AM
tail wheel
1 Attachment(s)
This install seems to hold up well. The old cow paster (flying field?) is pretty tough on planes. This is the tail of my 120 size. I did the 40 size the same way. I used 1/8" ply for the plate. Sorry I didn't shine it up but I spent a good part of today at the field and the heat really took its toll. Hope this helps.
flysforfun 08-07-2003 12:02 PM
Thanks for all the suggestions. I'll have to seek out a Sullivan at my local hobby shop. I like the idea of adding a little support plate, which will help threefold: 1) add re-enforcement to the fuse, 2) give someplace to screw into, and 3) give a little extra functional weight to a slightly nose-heavy plane.
GalenB 08-08-2003 01:49 AM
I used a simple DuBro free castering tailwheel on my US 40. Light and simple! The US has more than enough rudder authority!
I found that the spring from the Sullivan would have to be bent funny so that it would not interfere with the elevator so I decided against using it. The free castering really did work well...
