Need Help
Hello Everyone,
I have the yak 54 90-120 QB and i'm trying to choose the wright engine for it . Anyone has the experience which engine will work perfectly with this plane ? the plane is the yak 54 aeroworks . <br type="_moz" /> |
RE: Need Help
A link to the plane would help to point you in the right direction.
Buzz. |
RE: Need Help
Assuming it is this http://www3.towerhobbies.com/cgi-bin...?&I=LXYSX2&P=0
Engine: .90 -1.20 cu in (14.7 - 19.7 cc) 2 or 4 stroke with Pitts muffler Maybe a YS 115FZS or YS 140 Sport http://www.chiefaircraft.com/rcmsec/.../YS.html#ys140 |
RE: Need Help
If you want to use gas, go with the DLE 30. If glow is your preference, go with one of the YS's mentioned above.
Good Luck! |
RE: Need Help
I've seen the plane fly with a Saito 180 and it flies AWESOME. If I was going to buy one, I'd put a 3W28 in it.
RE: Need Help
How about a 120ax or dle20 for this airplane? Would it be underpowered?
Ameyam |
RE: Need Help
I had the YAK 90-120 a few years ago and I was running an OS 120AX 2 stroke swinging an APC 17X6 prop. It would 3D the plane fine but it was not overkill. Look in my gallery.
| All times are GMT -8. The time now is 06:13 AM. |
