RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Modeltech P-47 "maiden" (https://www.rcuniverse.com/forum/arf-rtf-75/1064102-modeltech-p-47-maiden.html)
Cyclic Hardover 08-17-2003 10:44 PM
Got that baby off the ground this morning. Every thing went well. I saw a friend of mine fly his a few months ago and was ready for the nosing over on takeoffs and landings.
* I have an OS 1.08 (inverted) up front which there is more than enough room for. Pulled just great with a 15/8 prop. Retracts were fine using Kavan wheels.
After a couple minutes of trimming, I started to relax but then a few more laps it was time to come in. I couldn't see the darn thing.
Gray and black was not good and my vision is still 20/15. I am going to add a couple of wide white strips near the out edge to help on those turns.
Definitely a keeper. :cool:
twostroker 08-17-2003 11:52 PM
Kind of amazing how long they stay in ground effect isn't it. Mine will stay a foot off the deck for a lot longer than you would think. Did yours' do the same? Mine is pushing the 10 pound mark with fuel so it was not expected at all. It is a keeper.
Cyclic Hardover 08-18-2003 12:20 AM
Yeh, I pride myself on takeoffs, especially on warbirds. I use alot of runway and just ease it off. You jerk one of these off the ground like a "stik" and that baby is coming right back down.
Mine came in at 9.5lbs. Funny, I didn't think many airplane guys knew what "ground effect" is. Take care.
twostroker 08-18-2003 12:57 AM
Probably less know what "cyclic hardover" is other than your RCU name.
TLH101 08-18-2003 01:28 AM
Is it possible to modify the wheel openings to install a more scale size wheel( ~4.5"), or is the spar in the way. I like the P-47 and am looking for something to put my 1.20 4stroke in. This one looks like it has reasonble outline, but those "Itty Bitty" wheels look rediculous. Besides, I fly off grass.
Cyclic Hardover 08-18-2003 01:38 AM
I don't have the plane with me at the moment so i am not sure on the wheel thing but the 120 should fit okay inverted with an opening in the bottom. I tossed the stock wheels and replaced them with Kavans. They are definitely a "plane saver."
*A small reminder is that I was still slightly tail heavy even with the 1.08 up front. :confused:
WayneR 11-12-2003 11:49 PM
RE: Modeltech P-47 "maiden"
I added a larger Robart wheel. Dont know the size off the top of my head, but I measured the wheel well, and used the size that fit a lil snug. retracts seem to work OK on test. Did grind a little of the wheel well out just for a bit more room. Haven't flown yet but the wheeld do look a lot better then those lil foam wheels.
