RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   EPP Eagle (https://www.rcuniverse.com/forum/arf-rtf-75/10671493-epp-eagle.html)
Fastsky 08-15-2011 06:39 AM
EPP Eagle
Hi, I have an EPP foam Eagle ARF glider on order and am wondering what is the best type of glue to use?[8D]
opjose 08-15-2011 10:05 AM
RE: EPP Eagle
For load bearing areas I use Foam Safe CA.
For other areas, plain old white glue does fine and dries invisible too w/o long term discoloration.
Fastsky 08-15-2011 11:09 AM
RE: EPP Eagle
Thankx Opjose. Will pick up some Foam safe CA. I have white glue all ready.
JohnMcGowan 08-15-2011 07:45 PM
RE: EPP Eagle
If yours is the EPP eagle thats shaped just like the real bird (?), I have one of these and I used gorilla glue to glue the 3 layer/tier wings together and foam safe CA for the body. I sueed the gorilla glue for the tailfeathers to mount to the body.Also get you some CA kicker for the foam safe CA glue as it took mine a while to stick without the kicker.
John
