RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   G.P. Pitts L- brackets (https://www.rcuniverse.com/forum/arf-rtf-75/1069381-g-p-pitts-l-brackets.html)
gare 08-19-2003 12:49 PM
If anyone is waiting on a new batch of L- brackets, they're back ordered but expected by end of month. Called this morning to check on the ones they promised me. I'm just antsy to see the difference. If that radius is larger, like Bill has described, that should certainly fix the problem. Mine are very thin at the 90.
bigflyguy 08-19-2003 01:29 PM
Hmmm... Very interesting. I was told 2 weeks ago it would be 1-2 weeks (now) before they would be in stock and shipping.
RonM 08-19-2003 02:46 PM
I was told shipping by the end of the month.
Quite the back-order for an item there was "no problem" with?
hmmm?
Ronm
rfw1953 08-19-2003 10:02 PM
What?
Didn't know they had a solution for this potential concern. How did you guys order them. Just email or call G.P. or Tower for the parts? I am assembling my second Pitts and would like to get this fix if you have any additional info would appreciate. Did they come up with a fix for all or just the 90 degree brackets?
iflyj3 08-19-2003 10:05 PM
Is this the 1/3 scale Pitts you are refering to?
Dan
RonM 08-20-2003 12:27 AM
Yes, the 1/3 Pitts.
Apparently, the first run had the radius to tight. The later version is supposed to have a gentler radius.
I just e-mailed GP support, and they said they would send replacements as soon as they were in. (Sept.)
Ronm
iflyj3 08-20-2003 01:37 AM
OK, thanks.
I have the updated version and the brackets have a good radius. However, the ones that go on the tail are formed according to the instructions, but incorrect as far as good aircraft practice. Example, on the horizonal stab the bracket is installed such that it loops back over itself. Under load this bracket would attempt to turn around by itself. I realize these are for looks only. If this is the case they should be installed correctly. I straightened mine out and reformed them to the correct angle. Look at any 1:1 at how they are installed for verification.
Dan
RonM 08-20-2003 03:23 AM
Dan:
I think the wires on the stab are functional. You should change them to work properly as you see fit.
Ronm
doctorgo 08-21-2003 01:03 AM
Pitts L-brackets
You don't have to wait for replacement brackets for your 1/3 Pitts from GP. Get to your favorite hardware store and get some National Hardware shelf bracket clips. Cut off the tang from one leg of the "U" and the flange from the other, spread it open to the needed angle, and there you have it! The holes are already in the bracket and at the proper location. These clips are 10% thicker and 50% wider and they're "soft" steel so will not fracture like the GP brackets.
Regards,
DrGO
bigflyguy 09-02-2003 10:17 PM
Tower's web site is now showing late September availability for the replacement brackets. I was told a month ago that I would have them in 1-2 weeks. Then I was told 2 more weeks, now another month! Meanwhile my Pitts just sits, ready to go except for a pair of .50 brackets. Where is this legendary customer service from Great Planes I have heard so much about?!? I think it stinks!
http://www2.towerhobbies.com/cgi-bin...?&I=LXDTM7&P=Z
