RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   t-34 question (https://www.rcuniverse.com/forum/arf-rtf-75/1069792-t-34-question.html)
fresnoflyer 08-19-2003 03:48 PM
t-34 question
While building my WM T-34 ARF, I noticed the the engine seems to have a bit of right thrust. Is this correct or did I just install it crooked? Also, one side of the fusalage near the engine seems to be straight, while the other side has a curve to it. Any thoughts.
Carlos Murphy 08-19-2003 04:12 PM
RIGHT THRUST
3 to 5 degrees is the norm, it's built-in to the firewall. I've built 5 of these things so just assemble as per instructions and it will be perfict.
Which engine?
fresnoflyer 08-19-2003 04:30 PM
t-34 question
OS .46 FX
Carlos Murphy 08-19-2003 04:45 PM
Engine
That's the most common engine used, I have a OS 50 sx on my present T-34, it hauls.
fresnoflyer 08-19-2003 04:50 PM
t-34 question
I chose the .46 because I was told that if I ever wanted to race it, that is the engine you must have. Also, the guy at my local shop told me that with that engine and a 9.5x8 prop, it would do 113 MPH
