Need to find...Please
Where can I find a device that goes in the tail of a airplane so you can use pull-pull on the elevator with servo near wing. I have a phoot I copied someplace...but do not know were to buy the device. Thanks Capt,nhttp://www.rcuniverse.com/forum/js/f...ey/msn/eek.gif
RE: Need to find...Please
I have the cables...ect....I need the device that the elevatorpush rods hook up too. Thanks Capt,n
not sure what you are asking then...
ball links? Clevis? |
It is a shaft that goes through the fuse with servo arms....then you hook up each elevator half to it. The pull pull is inside fuse to a servo that by cable(pull pull) works the elevator with one heavy duty servo near wing. Just cannot find where to buy it.
http://www.youtube.com/watch?v=58-NKoNsVXo |
Maybe if you show your photo someone will know what you are looking for. What you are trying to describing sounds like something someone made special. ENJOY !!! RED
ORIGINAL: captinjohn It is a shaft that goes through the fuse with servo arms....then you hook up each elevator half to it. The pull pull is inside fuse to a servo that by cable(pull pull) works the elevator with one heavy duty servo near wing. Just cannot find where to buy it. http://www.youtube.com/watch?v=58-NKoNsVXo if you are just trying to connect the elevator halves, then you can use hardwood dowels, carbon fibre rods... what ever.... |
ORIGINAL: captinjohn Where can I find a device that goes in the tail of a airplane so you can use pull-pull on the elevator with servo near wing. I have a phoot I copied someplace...but do not know were to buy the device. Thanks Capt,n[img][/img] |
http://www.hobbyking.com/hobbyking/s...0x28x12mm.html
Different sizes and cheap as chips. $14 dollar mark up on a $4 dollar part, shocking. |
Hi Captinjohn,
Is this the item you are after? http://www.hobby-lobby.com/pushrod_t..._1009_prd1.htm |
1 Attachment(s)
ORIGINAL: tande ORIGINAL: captinjohn Where can I find a device that goes in the tail of a airplane so you can use pull-pull on the elevator with servo near wing. I have a phoot I copied someplace...but do not know were to buy the device. Thanks Capt,n[img][/img] |
| All times are GMT -8. The time now is 04:16 PM. |
